Stack height help for a 389
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Black389, Sep 13, 2017.
  1. Black389
    Black389 Light Load Member
    181
    42
    Dec 1, 2016
    Indy
    i just placed an order for 8 inch Dynaflex stacks for a 389 and i went with 13,4 top stack. My question is will that be taller than my reefer (like stick higher?) i dont want to go under a low bridge and tear em off.
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    3,386
    7,836
    Jul 11, 2012
    in the bush somewhere
    How tall is your reefer? Most are no more than 13'6". So if you have 13'4" stacks, and a 13'6" trailer, and the stacks hit, they'll be the least of your worries.
    BigBob410, Mr Ed, crb and 3 others Thank this.
  4. QuietStorm
    QuietStorm Heavy Load Member
    899
    1,416
    Dec 11, 2016
    How could you not know how tall your trailer is while you're ordering parts yo make your truck look "cool"?
    13'4" are fine to answer your question on a standard size trailer. But seriously, just don't go under a bridge shorter than 13'6" like everyone else with a box doesn't do.
    crb, Bakerman and Black389 Thank this.
  5. Black389
    181
    42
    Dec 1, 2016
    Indy
    Ik trailer is 13,6. I wasnt sure how the stacks r measured. On the pic from the Dynaflex it says from ground up?
  6. rbrtwbstr
    3,386
    7,836
    Jul 11, 2012
    From the ground to the top of the stacks you don't wanna be higher than 13'6". I'm not sure but I think that's as high as you could legally go.
    QuietStorm Thanks this.
  7. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    You did not know how tall your trailer is? So you could have call DynaFlex and asked them also. IF it says from the ground up,,, then they are 13'4" from the ground up...
    crb Thanks this.
  8. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    No, they make trailers 14' high... mostly out west..
  9. Diesel Dave
    9,230
    29,461
    Jan 20, 2010
    Hesperia, Ca.
    From my understanding, the only thing that can be 14' is a load on a flatbed. Anything permanently mounted on equipment is 13'6". This is in California.
  10. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    I drove for Knight back in 2008, they had 14' trailers... very common out west where the overpasses are much higher than 13'6".
    FMCSA does not regulate the Height/width of trailers. This is a State to State thing.
    Federal Size Regulations for Commercial Motor Vehicles - FHWA
  11. 86mechanic
    86mechanic Medium Load Member
    372
    62,102
    Sep 6, 2016
    Northridge, CA
    Doesn't Gardner have 14' trailers ?
