stack size
Discussion in 'Ask An Owner Operator' started by Blkcowboy, Jun 29, 2018.
  1. Blkcowboy
    Blkcowboy Light Load Member
    282
    85
    Apr 11, 2018
    so i have never owned a truck with stacks is there any benefit.besides looks ...thinking about getting 5-6 inches on a 579......does anyone know what size tmc.stacks are using them.guage on how bigger i should.go?
  3. Diesel Dave
    8,723
    24,997
    Jan 20, 2010
    Hesperia, Ca.
    Mine are 7”, from the ground up they are 13’5”. You can’t go no higher than 13’6”. 7 and 8 inch diameter are the most popular. Also depends what kind of cut you want on the tip. It’s preference.
  4. Blkcowboy
    282
    85
    Apr 11, 2018
    slightly pointed at a 45 angle is there a correct term for it?
  5. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,522
    May 28, 2015
    The bigger they are.. and without mufflers... the farther out they keep others,awake at night when you idle.
    BARRRRRGGGGGG
    8" growl great if they're straight
    Diesel Dave Thanks this.
  6. 91B20H8
    91B20H8 Road Train Member
    2,946
    3,315
    Oct 17, 2012
    The Heart of the North, Mi
    Its called a salami cut
    Dave1837 Thanks this.
  7. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Hmmmmmmm. Around here they’re called slash cut.
    BigBob410, SAR, Ruthless and 3 others Thank this.
  8. wore out
    wore out Numbered Classic
    15,960
    193,144
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Miter cut?
    Straight pipes can't be blamed for bein heard across the lot. It's the folks that can hear them that are at fault. For drivin a truck without adequate noise prevention insulation. Reason 2 it's their fault if they want to sleep with the windows down and want it library quiet.
    autopaint, BigBob410, Oxbow and 7 others Thank this.
  9. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Slash, miter, chino, bull cut, straight, it does not matter with a DPF, and DOC no one will hear it. It will look like it's loud though.
    BigBob410, QuietStorm, Tug Toy and 3 others Thank this.
  10. Oldironfan
    5,777
    5,543
    May 22, 2017
  11. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    I have 6 inch miter cut straight pipes on mine with a small inline muffler. They are loud. Going to switch to 7 inchers when I get time. I’m not so sure you have any idea but you have a dpf and no matter what you put on your truck, you will never hear your pipes. Listen how quiet your pipes are now. They are already non muffled straight pipes from the factory. That would just be a cosmetic thing. Just throwing that out there in case.
    Blkcowboy Thanks this.
