Stalling a truck
Discussion in 'Questions From New Drivers' started by Mr. EastCoast, Dec 27, 2020.
  1. Mr. EastCoast
    Mr. EastCoast Light Load Member
    80
    65
    Aug 26, 2020
    What are the things that make a truck stall out?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,976
    19,014
    Nov 1, 2010
    Burnsville, MN
    Are you having a problem stalling out your truck?
  4. OldeSkool
    OldeSkool Road Train Member
    2,033
    6,464
    Jul 17, 2018
    New Hampshire
    Putting it in too high of a gear when taking off. Not downshifting quick enough going up a hill. Basically too high of a gear for where you are at.
    Running out of diesel or def will also stall one out.
  5. Judge
    91,843
    The PNDB on a Freightliner going bad or losing connection will shut it down quick too.
    Scoot 1971, D.Tibbitt and OldeSkool Thank this.
  6. blairandgretchen
    13,929
    76,539
    Dec 9, 2011
    South west Missouri
    Dumping the left hoof at a high rate of speed.
    D.Tibbitt and meechyaboy Thank this.
  7. AModelCat
    164,566
    Taking off in too high gear, trying to take off with park brakes applied, trying to take off with frozen brakes, steep hill/muddy conditions (see "too high gear" mentioned previously), lugging engine down too low, sick engine, running out of fuel/fuel restriction, restricted air intake, aftertreatment system plugged up, engine protection shutdown, loss of power or ground to ECM, broken ignition switch wiring.......
    Etc etc
    D.Tibbitt Thanks this.
  8. AKDoug
    AKDoug Medium Load Member
    323
    802
    Mar 21, 2018
    and if it's an old truck with Jakes that don't auto shut off at slow speeds, that'll do it too.
    D.Tibbitt, Coffey and AModelCat Thank this.
  9. meechyaboy
    meechyaboy Heavy Load Member
    796
    1,227
    Oct 4, 2018
    Detroit, Michigan
    Driver error... if you driven stick in a car it’s very similar. When I first started driving truck my main reason for stalling was when I came to a stop without downshifting all the way and leaving the range selector up when taking off. It’ll likely be a situation that you’ll be in until you pick up downshifting in the lower gears.
    Coffey and seagreg Thank this.
  10. seagreg
    seagreg Light Load Member
    288
    720
    Oct 3, 2019
    Forgetting to flip the range selector down when a light goes red seems to be the most common I see.
    Especially if you are in the habit of staring out in 3rd. Still driver error if you kill the engine before notice and deal with it.
    LoboSolo and Coffey Thank this.
  11. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,897
    Sep 20, 2015
    Southern Ontario
    Not quite a stall... One time I had the old Cat 3406B spinning backwards because I left the jakes on too long.
    Couldn’t drive the truck at all. No steering, no oil pressure and can’t find gears.
    Wasn’t til I shut the truck off and restarted then everything worked normally.
