Standard Clutch Force Pressure/Weight
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cruiser360, Jul 9, 2014.
  1. cruiser360
    cruiser360 Bobtail Member
    5
    What is the normal force required in pound pressure or weight, necessary to engage and/or hold the engagement of a standard clutch for the power unit of most combination vehicles used for interstate transport of freight?
  3. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Are asking about how much it takes to depress the pedal? That would vary depending on the design of the linkage and would change for different truck models.
  4. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    Sounds like he's asking spring pressure.
    In an Eaton example it mentioned clutch plate load of 3,200 lbs. That would be my best guess at an average pressure to clamp the discs.
  5. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    If that's the case it would vary by clutch torque rating, a 2050 for example has a clamp load of 4000lbs. It is usually listed in the clutch specs on the manufacturers websites.
  6. cruiser360
    5
    Sorry ... I should have been more precise. What I meant is the measured force/pressure/weight required from the human leg to depress/engage the clutch and/or keep it engaged.
  7. cruiser360
    5
    A range of force/pressure/weight would suffice to encompass the various models of truck out there ... a range from highest exertion level to the least will do. Thanks
  8. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    I doubt very much if anyone has information about that.
  9. cruiser360
    5
  10. Semi Crazy
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    Depressing the pedal disengages the clutch. Otherwise it is always engaged.
    English language - not everyone's cup of tea!
  11. cruiser360
    5
