Standard Transmission swap to Automated Transmission
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DD82ndAA, Nov 2, 2025 at 9:03 AM.
  1. DD82ndAA
    DD82ndAA Bobtail Member
    6
    Sunday
    This is my first post on this forum. I am an Army veteran with a right leg above the knee amputee.
    I drove manual transmission trucks for years before losing my leg mostly Peterbilt 379’s 18 speeds. It kills me not being able to drive manual transmissions anymore due to my amputation. I grew up around a bunch of old school truckers that were mostly die hard Peterbilt truckers. With all that being said I’m not looking for any sympathy. It is what it is. I may not be able to drive standards anymore but I still want to drive the model trucks I grew up riding in and learning how to drive. How hard and how expensive is it to swap a Peterbilt 379 longnose from a standard to an automated transmission? Spare me any negative or BS comments please. I’m looking for help and guidance on this journey I’ve decided to embark on. Any price points or shops that I could contact to do the work would be much appreciated. Thanks in advance for your time and help.
  3. W923
    W923 Road Train Member
    1,371
    4,200
    Feb 28, 2022
    Depending on the engine you want you might have issues getting the engine to communicate with the transmission. I assume you’re looking for something completely clutch free which would be a torque converter based transmission or a modern 2 pedal automated setup. The older amts which require a clutch is probably out of the question?
    what about trying to setup some type of air assist or air actuated clutch and still run an old school manual…not really sure what you can do with your prosthetic leg (assuming you have one)
    What are you wanting to do with the truck….otr local construction?
    Thanks for your service hopefully something here is helpful
  4. SmallPackage
    5,610
    17,897
    Dec 20, 2019
    Marion Texas
    Gonna be real hard to convert over in an electronic truck since engine and trans talk to each other by computer and need all the sensors and harnesses. Gonna just have to buy new auto truck if you need to have a new tech truck.
    If you want an old school mechanical tech truck and older Allison 5 speed would be the way to go.fully automatic, torque converter trans. They put them behind the big horse engines back in the day and they were very reliable. Monfort of Colorado tested a few behind the first 3406A’s with success.
    DD82ndAA and Sons Hero Thank this.
  5. lester
    2,921
    7,893
    Jan 2, 2012
    NW, Iowa
    What year did Eaton release the full auto trans? My 2001 379 was an autoshift, still had clutch pedal.
    How about some sort of hand clutch or hand throttle
    SmallPackage and DD82ndAA Thank this.
  6. DD82ndAA
    6
    Sunday
    My plan is to get a glider so I can pick which motor would work with what’s best for my situation. The motors that I would really like to be able to run are listed below.
    Caterpillar 3406E, C15
    Detroit Diesel Series 60, DD15
    I have a prosthetic leg a very high end one. The only issue with being an above the knee amputee is you have no knee or ankle to be able to really use any kind of pedal safely. So I am limited to my two arms and my left leg. I am looking into possibly getting some push pull hand controls for the gas/brake and using my left leg for the clutch. I’m not sure yet if the FMCSA will allow that kind of set up. If they do I will just run a standard transmission. Just in case they don’t allow such a set up I’m trying to figure out my options ahead of time. I’m trying to go otr, regional, and local whatever pays the best. I’m not familiar with an air assist or air actuated clutch how does that work? As far as the older automatics that require a clutch that is also a possible option as well as the modern 2 pedal automated set up. I’m really just trying to figure out which options I have as far as transmissions go with the above stated engines. Thanks for taking the time to try and give me some info and guidance with this.
  7. DD82ndAA
    6
    Sunday
    I’m not really interested in getting the newer style trucks. I definitely am looking for an old school mechanical truck. I will have to do some research on the Allison 5 speed transmissions. That sounds very interesting.
  8. Blu_Ogre
    Blu_Ogre Road Train Member
    8,312
    49,265
    Jul 14, 2013
    Out west
    This is going to be a bit of a brain dump, Bear with me though.
    As @SmallPackage said the modern Automated Manual Transmissions are part of a computer integrated system with the Engine.
    Since that's the way it is, the issue is getting all the harnesses and computers to make the SYSTEM work. I have been told the most effective way to change either way is to get a donor truck that is set up how you want so that everything can be moved over. Stuff transferred would include the harnesses and computers. May need to specifically include cab harness and cab computer, but I'm a bit vague on that.
    My 2010 Pete 387 had a Cummins with the Eaton auto-shift 10 SPD, once I got the programing updated it was fantastic. My opinion: the Eaton transmission controls became viable with a change that happened about 2010 model year. I would recommend doing research for which generation that trans was and not go any older.
    I would definitely have a preference for an 18 or 13 speed before another 10 speed. I would need to do research on the 15 speeds to figure out what game they are playing there.
    Newer Paccar products are not available with Detroit power. Opinion: I do not trust the MX engines and feel they are just a bit too small if hauling on the heavier side.
    Just saw your post about going with a glider. Not sure if you can get one with a DD15 and auto shift, which would be my preferred setup. But unsure if Paccar can/will supply that setup.
    DD82ndAA Thanks this.
  9. DD82ndAA
    6
    Sunday
    I’m looking into possibly being able to run hand controls for my throttle and brake. Not sure if that’s an option or not yet. It’s very hard to find any info on amputee truckers and there setups.
  10. Blu_Ogre
    8,312
    49,265
    Jul 14, 2013
    Out west
  11. DD82ndAA
    6
    Sunday
    I have a SPE certificate. At the time I did there evaluation I just used an automatic truck. So I have an SPE certificate with a manual restriction on it until I test again with a standard transmission truck which I do not have access to one to be able to install hand controls and see if they will accept that sort of set up. I’m in the process of trying to figure out what my options are with the FMCSA as well as the SPE evaluation with a standard truck.
