Start changing my own oil again....synthetic recommendations.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by nikmirbre, Sep 1, 2021.
  1. nikmirbre
    nikmirbre Road Train Member
    5,407
    9,729
    Jul 27, 2011
    High Point NC
    Im gonna change my own oil this weekend. I want to try to go full synthetic. I usually use 15w40 rotella. I have a Detroit 12.7
    Looking online, what is the weight I want/need?
    BigBob410 Thanks this.
  3. Big Road Skateboard
    6,120
    33,409
    May 2, 2021
    FYI, I changed from Rotella 15 40 to the T5 5 40 just two weeks ago. Dry engine before, and in my 10 day run I developed leaks at the thrust plate o ring and air compressor. Also seems like my oil pressure dropped.
    Made all repairs, and went back with Rotella conventional. My oil pressure has not recovered.
    Edit: I have not verified gauge accuracy yet, but it didn't change until it had the synthetic
  4. xsetra
    xsetra Road Train Member
    5,109
    6,972
    Aug 21, 2011
    What motor and year?
    Usually same weight 15w40.
    I use semi synthetic 15w40.
  5. nikmirbre
    5,407
    9,729
    Jul 27, 2011
    High Point NC
    98 12.7. I think I might go with a synthetic blend also.
  6. nikmirbre
    5,407
    9,729
    Jul 27, 2011
    High Point NC
    I have a friend who uses full synthetic and swears by it........no issues yet and same engine as mine. What engine you have?
  7. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    If the older engine is addicted to conventional Rotella for its prior service life, I would stick with it. The only advantage would be longer service intervals beteen changes.
    If you decide to switch to the 5w40 full syn. Watch closely for high consumption rates and low idle oil pressure when hot. More tired the engine, worse it will be.
    BigBob410, jamespmack and Dave_in_AZ Thank this.
  8. xsetra
    5,109
    6,972
    Aug 21, 2011
    The preferred lubricating oil is Shell Rotella SAE 15W-40 (CJ-4). Synthetic oils may be used in Detroit Diesel engines, provided they are approved by a Power Guard Oil Specification. The use of synthetic oil does not necessarily ensure the extension of the recommended oil drain interval beyond its limits.
    ...DETROIT DIESEL SERIES 60
  9. Mototom
    Mototom Road Train Member
    1,388
    2,703
    May 7, 2019
    Why would you choose conventional oil over synthetic? A high quality synthetic oil will have better properties all around.
    bzinger Thanks this.
  10. Big Road Skateboard
    6,120
    33,409
    May 2, 2021
    I've got a 60 Series. There's no doubt that synthetic lubricants are superior, and I wanted to push my service intervals out to 20k so I don't need to get it done on the road.
    Just thought I'd throw out what happened to mine. Ran it less than 10k.
    Usage did increase in that 10k. 2 Gallons first 2300 miles
    nikmirbre and Dave_in_AZ Thank this.
  11. Big Road Skateboard
    6,120
    33,409
    May 2, 2021
    From new, no one should.
    But an engine with many miles of conventional??
    Goodysnap Thanks this.
