Start while plugged in?
Discussion in 'Freightliner Forum' started by Ei, Jan 13, 2017.
  1. Ei
    Ei Light Load Member
    79
    7
    Aug 18, 2013
    Northeast
    is it safe, just kinda wondering, I usually unplug before I start the truck up!
  3. arrogant steve
    arrogant steve Medium Load Member
    444
    463
    Mar 31, 2016
    East Texas
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    You are doing it right.
    In case you get distracted by something then "Ouch 5hit I'm late" start driving you are safe.
  5. xsetra
    xsetra Road Train Member
    5,160
    7,092
    Aug 21, 2011
    Start plugged in or unplugged. Truck doesn't care, either way.
    Like snail said don't forget to unplug before you drive.
  6. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    What in the world are you talking about? lol
  7. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    If I had the trk plugged in whether home or the terminal I always started it up then immediately unplugged it.Its never hurt the trk.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If your ground wire or hot wireis not conn. inside heater correctly after many years of use or non use, you can get a shock when you touch the truck in wet weather while its plugged in, an it can cook starter + jolt the ele. system with 120 volt
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    Unplug the #### thing before you start.
    I spent years dealing with plugs for the engine block warmer. 120 cool volts waiting to kill you when you mashed that starter button that is metal on one hand with the other hand resting on the metal door...
    We had air start in them days so batteries was not a concern.
  10. Silentshifter83
    Silentshifter83 Bobtail Member
    29
    31
    Jan 15, 2017
    Everywhere, USA
    For the block heaters. In the frozen north we have to plug in our trucks in if we shut them off overnight. Its hard on motors to crank on them when its -30 degrees.
  11. RocketyMan
    549
    337
    Jun 5, 2015
    Ahh! Makes sense now. I imagine if you don't have a block heater, you crank times would be over 30 seconds?
