starter companies with automatics
Discussion in 'Questions From New Drivers' started by madagascar, Dec 10, 2013.
  1. madagascar
    madagascar Light Load Member
    56
    16
    Mar 28, 2013
    I searched the forums and found a thread from 5 years ago about starter companies with automatic trucks. Times change. Any updated info about starter companies with automatic trucks preferably for dry van? I already know about Comcar (CT/CTL) having automatic trucks but I'm not interested in flatbed or tanker.
    I'm a newbie that's already been with two companies in the last 3 months, I'm really hoping the 3rd time is a charm....
  3. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    If I can ask, what's wrong with the stick?
    blairandgretchen Thanks this.
  4. rwdfinch50
    rwdfinch50 Medium Load Member
    527
    595
    Nov 6, 2007
    Leesburg, Fl.
    I think almost all of the megas are running autos now. Your biggest problem is going to be getting hired having gone through two jobs already. It costs a lot of money to hire a new driver, and most companies won't take the risk of spending the money to hire a driver that will only quit.
    I suggest if you do get hired again, you stick it out for at least a year, no matter how bad it is, so you can show you have what it takes.
    For that reason, I would suggest staying away from some of the companies with the worse reviews, such as C.R. England. No sense using what may well be your last chance on a bad company.
    cabwrecker, Chinatown and Moon_beam Thank this.
  5. Bikerdave
    Bikerdave Light Load Member
    287
    81
    Feb 23, 2012
    Middle of nowhere TEXAS
    2 companies in 3 months! If you are lucky enough to get hired again, you need to stick it out. Another short term job and you might be just about untouchable
    blairandgretchen and Moon_beam Thank this.
  6. CrossJ
    CrossJ Bobtail Member
    7
    17
    Dec 10, 2013
    Indiana
    I'm pretty sure Carter Express runs mostly automatics. They have terminals in Indiana (Headquarters), Texas, Arkansas, Tennessee, Ohio, and Michigan. Also it's a mid sized operation so might be a better fit for you. I will be working for them after my training is through in about a month. I've heard good things so far. Hope this helps.
  7. madagascar
    56
    16
    Mar 28, 2013
    thanks for the advice. I think I might need to reevaluate my choices and leave trucking alone for a long while. I will keep my class A license because I worked really hard to earn them.
  8. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    USEXPRESS has automatics.
  9. BuckeyeCowboy63
    BuckeyeCowboy63 Medium Load Member
    495
    291
    May 28, 2013
    Cincinnati, OH
    Check USA Truck, PAM Transportation they have some autos....maverick has all autos.
    pattyj Thanks this.
  10. rwdfinch50
    527
    595
    Nov 6, 2007
    Leesburg, Fl.
    Make sure you have your DOT physical card info submitted to your state DMV, or in February, your class A will be removed from your license. I don't know the process in your state, but in Florida you can self certify online. I imagine other states have that ability too, but you'll have to check.
    Here's a link to the regs in case you want to see what I'm talking about; http://www.fmcsa.dot.gov/registration-licensing/cdl/faqs.aspx
    pattyj and blairandgretchen Thank this.
  11. DsquareD
    DsquareD Road Train Member
    1,439
    857
    May 21, 2009
    Green Bay, WI
    I believe Windy Hill in Marshfield, WI has automatics. They had a recruiter come to my CDL class back in 2009. I think they use paper logs too and are pretty loose with their requirements. They are a nursery and mainly run Wisconsin to Florida and back with lots of stops.
