Starter issues
Discussion in 'Mack Forum' started by Moe80, Jan 19, 2013.
  1. Moe80
    Moe80 Bobtail Member
    I have a 94 Mach E350 that will start half dozen times and then the starter just keeps spinning till you disconnect the batteries. Also the electrical malfunction light goes on and off on the dash. I've replaced the starter, solenoids on the firewall and ignition switch on the column. I'm all out of ideas can you help me please. Thanks a bunch
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    It sounds like a faulty harness where the solenoid from ignition start hot wire is shorting to the run hot wire. That's all you have is the ignition switch, starter relay on the firewall and the starter solenoid on the starter. If all them are new it can't be anything but the harness.
