I am trying to find a replacement for the small starter relay mounted to the top of the gear reduction starter used on the 07 Volvo D12. The starter part number is (Volvo)85103338. I know the small relay is a mitsubishi, but I am having no luck finding a replacement part. The dealer only sells the complete starter with the relay bolted to it, but I do not need the entire starter.. Any help would be apreciated.
Starter Relay Mounted on the top of the starter
Discussion in 'Volvo Forum' started by Damage, Mar 1, 2012.
http://www.ebay.com/itm/New-Starter-Solenoid-66-8398-Used-On-Mack-Mercedes-Truck-More-/190641190776
The interchange numbers should make your search easier. -
Coil resistance is 16 ore 30 ohm.
I used relays from end of life aircrafts (TKE ore TKD 120A rated). They all are 24V rated but click at 8V. LOL_)))))) -
You wire in a regular ignition relay. Complete with relay, mount, and harness for about $20.00. Napa sells them or any other auto supply place. Same terminal numbers so just cut and match. 85 86 87 87a 30. Any ignition relay with those posts will work.
http://www.texasindustrialelectric.com/relays_10511414.asp -
looks like mercedes Actros relay...
