Starter taking 8 to 10 seconds. It's fuel pump issue or ???
Discussion in 'Ask An Owner Operator' started by amjadjamal, Mar 10, 2020.
  1. SmallPackage
    5,475
    17,421
    Dec 20, 2019
    Marion Texas
    Not sure about Volvos but I had a Cat do this and it was the crank timing sensors on it. The two sensors would not communicate to each other fast enough to allow the ecm to kick off the run mode. Would take 10-15 sec of normal speed cranking.
  3. Dino soar
    Dino soar Road Train Member
    4,791
    26,878
    Dec 8, 2017
    Not to be funny, but are you sure the engine is spinning fast enough?
    I thought I had no problem starting my diesel pickup truck, but after I replaced the starter I could not believe how fast the engine spun.
    Over time even if the engine is turning more slowly you get used to the sound of it and think nothing is wrong.
    At least that was the story with my pick up anyway.
  4. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Yikes...I would "venture to say". (Sorry trying to bring this word back to popular...Probably the dreaded "injector cups" they use on the Volvos...with that many miles.JMO
  5. superhill56
    superhill56 Light Load Member
    216
    94
    Jul 28, 2016
    Powdersville, SC
    I have a 96 international with a 60 series that does the same thing. After you crank it for the day it’s fine but that first crank is a SOB. I’m not sure where to start
  6. Ridgeline
    22,418
    116,682
    What he said ....
    BUMBACLADWAR Thanks this.
  7. amjadjamal
    amjadjamal Bobtail Member
    6
    Mar 10, 2020
    Yeah, that makes sense. When right before turn off ignition if I depress accelerator n turn on in few minutes. It cranks right away. Thankyou
  8. amjadjamal
    6
    Mar 10, 2020
    Yeah, that's make sense. Thankyou
