Starting at TMC 9-14-09
Discussion in 'TMC' started by IL newbie driver, Aug 9, 2009.
  1. IL newbie driver
    IL newbie driver Light Load Member
    55
    Jul 11, 2009
    Burlington,WI
    I have been accepted at TMC and will be starting orentation on the 14th of Sept. Can any body tell me what to expect and how things will go? I will be fresh out of a driving school. How is the road test that they do with you? What kind of stuff do you do besides the load securement training?
  3. eckz
    eckz <strong>"Radio Rambo"</strong>
    896
    299
    Sep 15, 2007
    Detroit, Michigan
    The first few days will be in the classroom, you'll cover logs, safety, and operations, When i was there we had to do tests (This was years ago, not sure if that has changed)
    You'll do some yard training (Backing, learning to maneuver the vehicle, etc) which has to do with 45 degree, 90 degree, serpentine, etc. I know they took the serpentine out but i believe it was re-added recently.
    You won't do the road test until after you're finished with your trainer, at least back when i started we diddn't. You'll also be driving out on the road, they will try to get some day driving and night driving so your schedule will be a little odd.
    Make sure you aren't late for class, ever. Stay off the grass, try to get there the night before you start so you can get a good nights rest, if you can afford it i'd recommend getting a rental car, or driving yourself to avoid that greyhound, the earlier you can get there the earlier you will be settled in.
    Don't spend a bunch of money on TMC gear until you're sure you will make it, it's a job interview, you aren't actually hired until you are handed the keys to your own truck. The instructors will be tough on you, but they do it for a reason, they want to weed out the lazy people and the sissies before they blow a bunch of money training you, it's better that you leave the first day if you're having second thoughts than to keep spending their money on meals and training, etc. Just go with the flow, try to keep your head down and do what you're supposed to be doing and you will be fine.
    Good luck.
  4. IL newbie driver
    55
    Jul 11, 2009
    Burlington,WI
    How is TMC on where you park your truck when you go home? What kind of place do they require to park it at?
  5. eckz
    896
    299
    Sep 15, 2007
    Detroit, Michigan
    They never asked too much about it. They say that they require a fenced, secured yard, i haven't had to deal with it much because we had a small drop yard here where i parked my truck on the weekend as well as some dedicated accounts as well.
    Theres a few places in Chicago where we have dedicated accounts, (Chicago Metallic is a good example) the lot there is fairly small, but they may let you park there.
  6. Ltbig24
    Ltbig24 Bobtail Member
    38
    May 26, 2009
    Marshall Mi
    Hay IL Newbie just wanted to see how thing are going. Did you start on the 14th or did it get moved back.
  7. IL newbie driver
    55
    Jul 11, 2009
    Burlington,WI
    I am leaving this sunday to go out there but I will try and keep everybody posted and let you know what happens and how things are.
  8. TheRumRunner
    TheRumRunner Light Load Member
    223
    49
    Sep 6, 2009
    Louisville, KY
    Good luck! I got a prehire from TMC but chose Werner since i heard flatbedding was really slow right now..I will be in orientation next week unless i get a call from KBR soon.
  9. carterbeauford
    carterbeauford Medium Load Member
    362
    161
    Mar 21, 2009
    northwestern PA
    sweet, could you tell your new coworkers to stop running me off the road?
  10. IL newbie driver
    55
    Jul 11, 2009
    Burlington,WI
    I will be leaving today for training at TMC I will try and keep you posted on how it is going not sure if I will have access to a cumputer or not but will try and find one some where along the way.
  11. joecool313
    joecool313 Light Load Member
    146
    64
    Oct 9, 2008
    NorthEast
    FYI, They have a computer in the lobby of the hotel that anyone can use.
    Good luck, act professional and you'll do fine..
