starting problem on a 99 pete
Discussion in 'Peterbilt Forum' started by 99pete379, Mar 28, 2013.
  1. 99pete379
    99pete379 Bobtail Member
    14
    Feb 14, 2013
    On my 99 when you go to to start it it just clicks then push the button 3 to 6 times then it starts the truck tjen it works good for a while then it does it again when u trun the truck off bruch of times in a roll
    I put a new starter battries in and cables any idea what else it could be
  3. WorldofTransportation
    WorldofTransportation Heavy Load Member
    702
    577
    Sep 20, 2009
    Your mother
    Call Pete and find out where the switch on the firewall is I forget what it is called.. On mine which is older than yours. it is right under the footvalve.. (the valve with all the colored plastic air lines on it) When you find this switch make a jumper wire..and bypass the switch with the key on and out of gear.. if it starts that is where your problem is... If not you have a bad ground ... Good luck
  4. 99pete379
    14
    Feb 14, 2013
    Ok thank you ill look for lt
  5. ost1
    ost1 Light Load Member
    54
    22
    Mar 28, 2013
    I just went thru this on a 03 379. Behind the battery box up near the frame rail there should be a junction block. It's a ##### to find but the hot wire nut on mine backed off just enough to cause the same problems. I did the starter then batteries, the whole deal. nothing worked. till I found the little box by accident. I thought it was a relay/solenoid but I don't think it is.
  6. manasteel
    manasteel Light Load Member
    124
    32
    Sep 10, 2012
    the wire harness that leads from the starter solinoid top of firewall is zip tied/ clamped to the a/c line down the firewall 6" above the steering coloumn you will find a connector, some are 2 wire some are 4 wire you will find the pins in the connector have melted. the connector will not want to come apart because it has melted cut this out and splice the wires back together
  7. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    910
    Mar 16, 2013
    Needs a new switch. My opinion. My 2000 was the same way I'd have to wiggle the switch or hit it several times then shed hit just fine.
  8. Lone Ranger 13
    Lone Ranger 13 Road Train Member
    1,542
    1,298
    Sep 27, 2012
    Asheville, NC
    Sometimes my 98 379 would crank and sometimes not at all. It was a bad ground on starter relay. The relay on my truck was located on firewall on left side, under the hood (engine compartment that is). I added an extra ground to the frame. Fixed it.
