Starting problems!!!
Discussion in 'Freightliner Forum' started by mickutzu2011, Oct 25, 2016.
  1. mickutzu2011
    mickutzu2011 Bobtail Member
    16
    I have a problem when i cold start my 05 columbia. It shakes, lights go crazy and a passing driver said he saw sparks under the truck. After that is doesn't do that until next cold start. ECM volts goes up and down. Battery's are new. Thank you!!!
  3. xsetra
    xsetra Road Train Member
    5,173
    7,108
    Aug 21, 2011
    Sparks under your truck?
    I would look for a loose cable arcing.
    Have someone else watch your truck when you start it, to verify sparks.
    Good Luck
  4. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    check connections to starter are tight and not loose. replace both ground cable chassis to starter and chassis to batteries this should take care of your problem
