Static noise
Discussion in 'CB Radio Forum' started by Harley, Jun 30, 2008.
  1. Harley
    Harley Light Load Member
    291
    32
    Jan 13, 2008
    I have a Cobra 29 classic thats been peek'd and tuned well.
    I get alot of static when the truck is upshifting and down shifting.
    What causes this and what can be done about it?
  3. Truckerjo
    Truckerjo Road Train Member
    2,314
    341
    Sep 5, 2006
    Indiana
    Better ground... Try hooking your radio to a different power source..
  4. I80RoadWarrior
    I80RoadWarrior Bobtail Member
    11
    Denver, CO.
    That or what I've done and works great is a 20 amp noise filter. Cheapest place I've seen them is Auto Zone.
  5. Harley
    291
    32
    Jan 13, 2008
    Thanks guys. I try your ideas and see how it works out.
    Thanks again.
  6. Area904
    Area904 Light Load Member
    93
    9
    Jun 6, 2008
    Jacksonville, Fl
    Computer controlled shifting (autoshift)? You may be picking up radiated RF from the computer, relays, or associated wiring. Make sure all bonding (grounding) wires are in place between computer, transmission, frame, engine, etc., and all RF shields are in place. Make sure your radio and antenna mounts are properly bonded (grounded).
    RF noise is one of the hardest problems there is to locate and fix properly.
  7. I80RoadWarrior
    11
    Denver, CO.
    Another serious irritant that can't be cured, along with the above, is the brushless alternator used by many 2007 model engines. No matter what you do to ground radio and antenna out, noise level stays at 50% of meter. Good luck.
