Staying cool in summer
Discussion in 'Questions From New Drivers' started by Friz, Mar 17, 2014.
  1. Friz
    Friz Light Load Member
    71
    28
    Jul 18, 2013
    Weatherford, TX
    I started driving just in time to learn how to stay warm in sub freezing temps.
    Tonight is the first night that the bunk heater isn't clicking away. It's only in the mid 70's and it's smoking hot in the bunk, even with windows down and vents open.
    The company I drive for has a 25% idle rule to qualify for bonus.
    Aside from idling, how to you stay cool in the middle of summer?
  3. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    I have a 12V fan in the bunk across from my head up high to blow some air around..I even use it in the winter sometimes to keep the air moving. It'll help ya anyways and shouldnt kill your battery while the truck is off
    Friz Thanks this.
  4. jsprocket
    jsprocket Heavy Load Member
    830
    262
    Nov 4, 2013
    Columbus, GA
    I got bunk heater that has a\c
  5. Chinatown
    Chinatown Road Train Member
    73,365
    164,969
    Aug 28, 2011
    Henderson, NV & Orient
    Any new CDL grads or students reading this maybe should consider a company with APU equipped trucks.
    Ann Eiffel, Longarm and Balakov100 Thank this.
  6. Balakov100
    Balakov100 Road Train Member
    3,937
    2,635
    May 10, 2012
    Temple, TX
    Guess you're just going to have to Idle.
    You can try all kinds of creative ways to save your company money.
    There's only one thing that really works..they may or may not like it.
    Chinatown Thanks this.
  7. kbar909
    kbar909 Light Load Member
    I have heard good things about this product. I plan to get one! I think it will be worth the money!
  8. Longarm
    Longarm Road Train Member
    1,292
    30,855
    Jun 2, 2011
    A trick that works pretty well as long as you're taking your break after the sun goes down. Before pulling out from the last break you plan to take before taking your ten, pull your bunk curtains and crank the AC in the bunk. After a couple three hours, your bunk should comparable to a refrigerator when you first shut down. This doesn't work if you're taking a break during daylight hours with the sun beating down or temps above 80 or so depending on other weather conditions.
  9. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Yes, in Houston or Louisiana, in May following a wet spring, roll down your windows to try and stay comfortable and get back to us how that went.
    Refuse to work if they don't provide modern devices such as an APU, problem solved.
  10. Friz
    71
    28
    Jul 18, 2013
    Weatherford, TX
    Sweet!!!!!
  11. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    screw the bonus and stay comfortable.if you run hard,you should idle away with the a/c fogging your windshield and sleep without sweating. DO NOT BE JOB SCARED.they will not fire you and that bonus can't equate dollar with comfort and sound sleep.
    chiprighter, Chinatown and Ann Eiffel Thank this.
