Hi guys>
I have owned a 2007 Volvo VNL 780 w/ISX. I'm having an issue that boggles the mind of myself, the Dallas Volvo dealer and various mechanics. For no apparent reason I'm having an issue with being legal on my steer axle. I've hauled many 40k loads and had no problem getting legal until recently. Loaded a trailer with a 20k, evenly loaded front to back load. My steer axle weighed at 12800. Weighed with an empty trailer and !/2 fuel full tanks and got 11880 on my steers. Bobtail weight is 11780 on my steers. Picked up a 10k load with full tanks and weighed at 12100 on my steers. In essence, it appears my steer axle has magically and for no apparent reason taken on weight that puts me close to the legal limit without a load on. All weights were done with the 5th wheel in the rear position and trailer tandems slid forward. As this issue is preventing me from my livelihood, you can only imagine my frustration. Any ideas, suggestions or direction to get ideas/suggestions would be greatly appreciated.
Steer axle weight issue
Discussion in 'Volvo Forum' started by Robert kinkaw, Jul 8, 2016.
Page 1 of 4
Make sure your drives are not rolling onto the steer platform, at the scales.
Im guessing you have large fuel tanks and your fifth wheel is all the way forward?
You do know moving the fifth wheel works opposite the tandem slide..fifth wheel movement moves weight the direction you move it. -
The name of your prob
Isx
My 670 with 200l fuel was 300lb higher on waight as my 780 with a d13 is
.... i swith a trailer between them same liad on -
I would take a really close look at the rear suspension. under load, weigh each one of those axles individually and see if the weight is distributed evenly or if one axle is sluffing it's weight forward. That might tell you something about what is happening.
Release your brakes when weighing.
Bobtail weight should not be 11,800 on the steers, unless the truck is specd with a heavier axle, wheels and tires.
Ive never weighed more than 11,000 lbs bobtail, and my fifth wheel is all the way forward.Robert kinkaw Thanks this. -
How much gear do you carry?
Do not set your trailer brakes while scaling and this will correct your issue.
Is the steer axle air ride?
magoo68 and Robert kinkaw Thank this.
Page 1 of 4
