Steer axle wheel seal replacement same as drives?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wildcat74, Sep 2, 2011.
  1. Wildcat74
    Wildcat74 Medium Load Member
    354
    128
    Jul 15, 2008
    Omaha, NE
    As the question asks, is it relatively the same process? Any surprises on this job? Seems like everything on my truck has decided to take a dump on me all at once.
  3. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    Yes its the same except you don't have to mess with pulling the axle shaft out like on the drives.
    Wildcat74 Thanks this.
  4. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    If you ever had to do a trailer axle... same thing.
    Might I suggest that you replace the double nut with a Torques nut ?
    I've switch my trailer to them 5 yrs ago and have been very satisfied.
    Its a single nut about 3/4" thick and uses a locking ring that fits inside the nut to secure it. No more busted knuckes and no more having to dealing with 2 1/8" nuts.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yeah, like a trailer axe. easier job then drive axe replacement. follow axe manufacter's manual, especially with meritor and SAF axes.
    On some axes use 4' socket to unlock nut.
    On some Volvo truck single use self locking nuts are used. You remove nut and it cant be reused. So identify axle first. Now it is easy to get any axle manual in internet
    what a truck do you have? what axle?
  6. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    How do identify the steer axle? Truck is an 83 Pete 359
  7. highside
    highside Medium Load Member
    441
    510
    Feb 6, 2010
    Kansas
    Easiest way is to call your Pete dealership and give them the last 6 of your VIN...assuming the axle hasn't been changed out previously, they'll be able to tell you what axle the truck came out with. There's usually an ID tag somewhere on the axle that can identify the brand and model.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    there is a small ID plate on axe held with small riviets.
