Steer axles
Discussion in 'Questions From New Drivers' started by Arkansas Frost, Aug 26, 2012.
  1. Arkansas Frost
    Arkansas Frost Heavy Load Member
    897
    486
    Aug 2, 2012
    North Little Rock, AR
    Ok, IN has the stupid steer axle max at 12,000 lbs. I was thinking, foolishly, less weight up front and more in the rear should help... So I slid the tandems. Gained 40 lbs. CRAP! I don't have time to be screwing with this in the morning. Do I have to slide my fifth wheel or just go the other direction with my tandems? I havent really had this problem before but I know if I don't fix it I'm gonna end up getting sum ### scale me in the morning and there will go my week! Steer 12,400; drive 31,62; tandems 33,000. Anybody?! Cant idle long enough to lose 400 lbs either... HELP
  3. Arkansas Frost
    897
    486
    Aug 2, 2012
    And MI says 700 psi per tire width! WTH?!
  4. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    Slide your 5th wheel back a notch or two. This will take weight off your steer and onto your drives.
    CAXPT, Sam Hell and Arkansas Frost Thank this.
  5. jbatmick
    jbatmick Road Train Member
    2,197
    2,499
    Dec 1, 2009
    hastings, Fl
    If you can, slide your fifth wheel back just a little.it might be easier if you wind down your landing gear before you slide it. Taking some weight off the fifth wheel makes it easier to slide.
    Sam Hell, Arkansas Frost and CAXPT Thank this.
  6. Arkansas Frost
    897
    486
    Aug 2, 2012
    And once again TTR beats dispatch by a mile. Thanks, I kinda thought so but this beats trial and error. If this doesn't work in the morning expect a lengthy complaint! Never mind that it will go down in your permanent record. If it works I'll say thanks again when I stop, lol
    CAXPT Thanks this.
  7. the gambler
    the gambler Medium Load Member
    330
    245
    Feb 14, 2011
    Kentucky
    As said in an earlier post lower the landing gear and drop the air out of you suspension on the drive axles before you slide the 5th wheel. Also make sure you 5th locks re-engage.
    CAXPT Thanks this.
  8. ukdon
    ukdon Light Load Member
    171
    71
    Pensacola, FL
    I've been through Indiana many times with steers over by 300 to 500. Don't have a slider for fifth wheel. Never been questioned a single time or pulled over. I was never over on gross.
  9. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    about 3 teeth on the 5th wheel should do it.. but, what's your fuel status? Always try to leave room for fuel weight too, roughly 7 lbs a gallon.
  10. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    Jimmny cricket, Call Your Travel Agent, I,m over weight, what shall I do. Don't make the mistake of what the company might do. Your the Driver, that's all. Unless your an O/O then it's your problem.
  11. Saddletramp1200
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    There is almost 1 thousand tons of freight left at chicken coops donated to charitys every year. Better than a fine.
