Need some help.
New to me truck, 07 Pete 387
Steers look to be 80 to 90%.
Air preasure at 110%
24" full size.
Inside of passenger side is starting to dip a little, drivers side is even.
I have driven truck regional for the past few weeks. Around 1900 miles.
Pulls a little to the left, and has a slight vibration in the steering wheel, not to bad through.
385K miles.
What could be causing the dip.
Thanks
Steer Tire Dipping
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NCBirdman, Nov 23, 2011.
Page 1 of 4
Do you mean cupping ???
Bad kingpin or worn shocks can cause that. -
Alignment
Tire Pressure
Loose Wheel Bearings
Worn Shocks -
Yep, mean cupping.
Tire pressure is same on both tires.
Slight pull to the left would prob mean out of alignment.
I will have to get it check out before it gets too bad.
Thanks -
Got any pics? Are you talking about thread wear? it sounds like the alignment or suspension could be causing uneven wear.
Shocks, wheel bearing, negative camber, too much caster on one side, king pin, rear axles out of alignment. If the rear axles are out of alignment, you will have outside wear on one steer tire, and inside wear on the other.
Most places will put it on the machine, and if it's within specs, they wont touch the caster and camber, even though that will be your problem. The secret is getting the cross degrees between the two sides to be close.
Try Caldwell Alignment on 321 in Hudson, which I consider extremely good, or Custom Alignment on hwy 18/64 just out of Morganton, going toward Lenoir. Both are old school places that fix it right. -
Mine was cupping on the right really bad. Had a bad shimmy at 45mph. It was a bad shock.
We used Cladwell back in the day, they were very good.
They would actually shave tires to get them true.
@popmartian I do not have any pictues of the tires, ust got back in, I will upload some in the mornig.
Thanks -
I used to buy new tires, run them a few thousand miles, then have Caldwell true them. Smoothest ride ever.
Just a bad shock caused cupping on one side? You only got the shocks replaced and this curred it?
Page 1 of 4
