Steer tires only lasting 50K miles??
Discussion in 'Experienced Truckers' Advice' started by WisconsinF150, Sep 4, 2016.
  1. WisconsinF150
    WisconsinF150 Light Load Member
    297
    213
    Dec 21, 2014
    I came across a driver the other day.
    I saw him back into a dock.
    I later asked if he had trouble with his steer tires needing to be replaced every 50,000 miles. He said yes, and we can't figure out why they only get 50k miles.
    I told him that I was watching him back into the dock and told him why his steer tires were wearing so quickly.
    When he pulled forward, he would look in his mirror and start turning the steering wheel, and THEN would back up.
    I explained that he should never turn his steering wheel unless the truck is moving. The 6 tons of weight on the steers, 3 tons per steer tire pushing down while twisting the tire is grinding small flat spots into the tire.
    If you turn the tire while the tire is rolling, it spreads the wear and tear evenly across the tread, extending the life of the tire.
    Lepton1, double yellow and Toothpick1 Thank this.
  3. sliver
    sliver Light Load Member
    230
    242
    Feb 17, 2015
    idaho
    Ok. Getting popcorn.
  4. SHOJim
    SHOJim Road Train Member
    3,399
    17,210
    Apr 19, 2011
    Columbus, Ohio
    Did Millis Transfer teach you this?
  5. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    For better results, bring a spray bottle of soapy water to spray on the tires, reducing abrasion while turning.....
    Dave_in_AZ, TGUNKEL, sliver and 3 others Thank this.
  6. driverdriver
    driverdriver Road Train Member
    4,254
    5,283
    May 30, 2011
    I offen turn my wheels before rolling especially in tight places when I need the tractor to react as soon as I begin to roll.
    I don't have a problem with my steers lasting more than 50k
    Where did you come up with this nonsense.
  7. FlexinTarzan
    FlexinTarzan Medium Load Member
    571
    655
    Jan 8, 2012
    Stanfield, OR
    The OP is the one who kept searching for the Blinker Fluid Reservoir after instructor said the fluid was low ....
  8. Moosetek13
    Moosetek13 Road Train Member
    14,660
    18,408
    Nov 1, 2010
    Burnsville, MN
    The idea of more wear on the tire by turning while stationary is not nonsense. It is true.
    But unless you are doing it for most of your driving day it probably won't affect tire wear all that much.
  9. SHOJim
    3,399
    17,210
    Apr 19, 2011
    Columbus, Ohio
  10. Superquack
    Superquack Medium Load Member
    338
    116
    Mar 7, 2010
    And the DOT-4 air brake fluid
    SHOJim Thanks this.
  11. SHOJim
    3,399
    17,210
    Apr 19, 2011
    Columbus, Ohio
    I think he tried to feed and water his steers
    Dave_in_AZ, TGUNKEL and sliver Thank this.
