Steering is too easy
Discussion in 'Volvo Forum' started by tanksalot, Feb 18, 2013.
  1. tanksalot
    tanksalot Bobtail Member
    20
    8
    Mar 3, 2012
    Canada
    Hi, in my 99 Volvo WG64 with TRW Steering box, the steering is too easy with no return to center.
    I've dropped the pitman arm with the axle raised and there is no binding when turning the wheels by hand. I suspect the gear box.
    An online search did not lead to any new insight, although several 4 wheeler forums report the exact same problem in just about every brand.
    How about you guys, any experience with this?
  3. Hammer166
    7,572
    27,593
    Aug 18, 2007
    ~8600+' and loving it!
    No return to center is an alignment issue, and overly light steering likely is as well. I'm guessing driving it straight down the road is like trying to push chain?
  4. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Was wondering if air pressure was to high in the steers? Could be causing that. Riding on just the center of the tread.
  5. tanksalot
    20
    8
    Mar 3, 2012
    Canada
    Truck drives straight as an arrow, bobtail or loaded trailer. Tire wear is excellent.
  6. tanksalot
    20
    8
    Mar 3, 2012
    Canada
    No, tire pressures are good all around. Certainly has me scratching my head. The dealer says to change the steering box and I may, but as that is the most expensive route I want to eliminate as many possibilities as possible first.
  7. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Yes that needs to be a last resort.
  8. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    may be valve body torsion spring loose/broken. it is easy to change valve body, it is located on top of steerbox. Use TRW PDF manual to read how to.
  9. StrayKat
    StrayKat Bobtail Member
    14
    11
    Feb 14, 2013
    North East Texas
    Had the same problem once on a Volvo. Turned out to be the power steering was in constant bypass/boost due to a faulty (stuck?) valve.
  10. tanksalot
    20
    8
    Mar 3, 2012
    Canada
    Okay you and StrayKat seem to have the same idea, I am going look into that tomorrow.
    Thanks, I will let you know what I find.
  11. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I had a filter come apart in the power steering reservoir one time and it jammed the valves in the pump. Felt like you were steering on ice it was that easy and it wouldn't return to center unless done manually, was alot cheaper than a steering box.
