Steering wheel question!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rigbuilder, Sep 22, 2014.
  1. Rigbuilder
    Rigbuilder Medium Load Member
    335
    103
    Jun 17, 2013
    Bedford, Texas
    We have a 2010 Freightliner Cascadia and we cannot figure out how to disable the horn. (Not the airhorn). Any help would me appreciated. Our dog is honking while we are inside and it's starting to piss off other drivers.
  3. Chris50
    Chris50 Medium Load Member
    347
    215
    Jun 21, 2010
    Florida
    Be careful, if you get a dot inspection he will ask you to honk both. At least thats what was done to me. Maybe pull the fuse when you are out or put it on a switch?
  4. Rigbuilder
    335
    103
    Jun 17, 2013
    Bedford, Texas
    Any idea how to put it on a switch?
  5. moosc
    moosc Road Train Member
    3,284
    1,172
    Mar 5, 2009
    Lincolnton NC
    Build a cap to cover the horn or paddle the dog 🐶 every time they do it. Theyll learn not to do it.
  6. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Find the horn under the hood and cut one of the wires and connect a wire to each end, run it into the cab and onto a switch.
  7. xsetra
    xsetra Road Train Member
    5,172
    7,107
    Aug 21, 2011
    Dot horn requirement is either air or electric need to operate. Not both. Also you have a couple wires coming out of your steering column that control the horn. If you don't want to find those wires do like Skate-board says. Or get one of those steering wheel desks that hook on wheel and cover the surface. Your dog would not have access to your horn button. Good luck
  8. rollin coal
    rollin coal Road Train Member
    13,488
    27,544
    Mar 29, 2008
    TN
    Then why on an inspection do they always check to make sure both the city and air horn are operable? If you only need one or the other?
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    usually bad clocspring... to change it u have to remove steering wheel, but if your truck has ESP clockspring is combined with steering wheel angle sensor and u have to fit it in correct position (put steering wheel straingh forward before u do this stuff and fit it back in the same position)
    Check brake system configuration before u order part. Steering wheel sensor is expencive.
  10. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    You are absolutely right. I've seen truck that don't even have an air horn.
  11. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Pablo, he doesn't have ESP, he has a DOG :) There's nothing wrong with his horn, it's his dog pushing the button. Relocate the horn on the dash facing the steering wheel. It'll only take a day or 2 before the dog will refuse to touch the steering wheel, then you can put it back.
