Step Deck operator need your advice
Discussion in 'Flatbed Trucking Forum' started by kachup, Oct 29, 2013.
  1. kachup
    kachup Medium Load Member
    312
    305
    Oct 23, 2013
    How many of you guys are running 51x102 SD, just bought a 2014 [FONT=Arial, Helvetica]REITNOUER. 40.5 bottom and 10.5 top, how many of yall tell the shipper you got a 53? or do you just call for 53ft loads and tell them you got a 51ft? whats best option?
    and whats the best way to run these trailer, spread axel or tandem?
    I dont want the frame to get weak on me with time. First all aluminum Flatbed
    [/FONT]
  3. DeltaKilo
    DeltaKilo Bobtail Member
    35
    16
    Oct 3, 2012
    Chicago, IL
    Buddy of mine who works step calls it what it is. At the worst - he gets told that it is a no go. Usually it's no prob for him
  4. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    If you're light close it. Tell them it's 51 worst they can do is say no
    DeltaKilo Thanks this.
  5. snowwy
    snowwy Road Train Member
    20,600
    13,322
    Jul 6, 2009
    i haven't hauled many loads that were over 48 feet. occasionally a 53 or less comes along. but when calling on the load. they'll usually ask you on length if it's over 48.
    most of the loads i've hauled on the east have been light. and ran through tennesse which is a closed axle state. on the west they are heavy and unless going into cali. you can run spread.
    on the east i only had to worry about new york and everything else east. w. virginia. tennessee, south carolina, florida, wisconsin, minnesota, and michigan. according to atlas. connecticut is 37 feet form front axle.
    i have a 53 and compiled a list from the atlas of closed axle states.
    my understanding with canada is 20k on spread compared to 40k in america. close the axles and you can haul 34k like america allows.
  6. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I only open my spread when my gauge reads close to 34k. I always keep it closed when I'm empty or when I know I'm picking up a light load.
    I tell everyone I have a 53' even though it's just 51'6" ;)
  7. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,890
    May 1, 2013
    In purgatory
    Nope. You can run a spread from Ontario, I think all the way east. Western Canada from BC thru Manitoba, close it up...and Canadian weights allow 17,000kgs ~ 37,500lbs on tandems.
    Quebec has lower weight limits during the spring thaw, but I don't go there enough to know it off the top of my head.
    not4hire Thanks this.
  8. Grumman
    Grumman Light Load Member
    289
    120
    Nov 7, 2009
    Locust Grove, GA
    When I used to run a 51' I would ask, "why do you need a 53', would a 51' work". The majority of time they just need 40' on the bottom. I think some brokers didn't realize there was anything other than a 53' or 48' out there. Every once in a while they actually mandated a 53' because they wanted 43' on the bottom and didn't want anything to hang over. Most of the time if the broker didn't know for sure they'd call their customer and ask if the 51' was okay. Sometimes nothing but a 53' will do.
  9. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Don't ask. Just show up especially if the shipper is close ;)
  10. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    tell em it's a 51', but that you carry a load shrinker for 53' loads.
    milskired and Cluck Cluck Thank this.
  11. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    I run my 51' step as a spread and closed. When the load goes past the tandems, I will open the spread. It rides much smoother as a spread. With them closed, it tends to bounce a lot. I also run it open when I have a container on, as it seems to to help the stability in the winds.
    ALWAYS open the spread when you loading from a dock (forklifts, machinery and so on) so that you don't bend the frame/rails.
    Logan76 and Cetane+ Thank this.
