Sterling ignition issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brownm1579, Jan 22, 2021.
  1. Brownm1579
    Brownm1579 Bobtail Member
    Been working on a 2006 9500 for some time now. Intermittent no start no crank. Starter tested bad so replaced that. Also replaced the pdm and mag switch along with all battery and ground cables from battery to pdm due to corrosion. Voltage is good at starter and switch but as soon as you hit the push button the relay clicks once and trips the switch and lose power everywhere. Dealer has been a PITA and I don't have access to DTNA. Any idea where to go from here? Noticed a little Voltage drop with alternator connected by but still lost power when hitting the push to start
