Sterling w/Detroit
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by steve092, Jun 10, 2021.
  1. steve092
    steve092 Light Load Member
    298
    79
    Dec 7, 2015
    Hey guys I've got a 07 Sterling dump truck with a 14L 60 Series Detroit. It started to randomly act up.
    The turbo stops spooling and truck starts to smoke up from the exhaust. It randomly goes away and the truck starts to run fine for a few days and does it again.
    I've replaced the boost pressure sensor, inspected the turbo, fins are good, spins freely, no wobble, no oil.
    What is going on! The shop says there are no active engine codes that are on.
  3. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    sounds like the vpod is going out
    steve092 Thanks this.
  4. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
    If it is a 07 it will be a DDEC 6 so no vpod. It will have a VGT turbo with an actuator. There are tests that need to be run on turbo/ injector performance with laptop that has DDDL 8.07 or higher version installed on it.
    little cat 500 Thanks this.
