still cold out..so,whats the best way to...
Discussion in 'Ask An Owner Operator' started by lowjo, Jan 16, 2015.
  1. lowjo
    lowjo Light Load Member
    81
    7
    Nov 19, 2009
    arkansas
    remove company stickers/dot numbers/truck number ? i dont have a heat blower or hair dryer. im looking for solvents to help,or something?
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    When I had mine removed thy used a drill with a round rubber attachment, It worked like a big eraser and took off the stickers without hurting the paint. Not sure where to get one though.
  4. lowjo
    81
    7
    Nov 19, 2009
    arkansas
    that sounds good
  5. tnevin225
    1,166
    1,601
    Jan 1, 2014
    [TABLE]
    [TR]
    [TD="align: centervertical-align"] Have one to sell? Sell now
    [/TD]
    [/TR]
    [/TABLE]
    [h=1]POWERTEC STRIPE & DECAL BODYWORK STICKER REMOVER RUBBER WHEEL TOOL. I found it on E-Bay[/h]
    savage02 Thanks this.
  6. lowjo
    81
    7
    Nov 19, 2009
    arkansas
    no time for shippin. thanks though. im gonna try the turtle wax label remover. the you tube demos looked decent enough. thanks again.
  7. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    The turtle wax label remover will be tough to use under 32 degrees. I think it even says it on the product. If your doing it outside and it's below 15 degrees don't waste your time and money. De-natured alcohol will aid you if your below freezing. Paint thinner is best but obviously it is Not paint friendly.
    lowjo Thanks this.
  8. lowjo
    81
    7
    Nov 19, 2009
    arkansas
    around 30/35 or so tomorrow morning. i was looking for some technical info on that stuff,thanks.
    i used a lighter and starter fluid(blowtorched it) for heat last time i did a removal. dont really wanna do that,but i may have to again.
  9. rollin coal
    rollin coal Road Train Member
    13,288
    26,800
    Mar 29, 2008
    TN
    I have a solvent in a 20 Oz coke bottle given to me by the graphics shop that did my lettering. Use a 3M eraser wheel to remove the decals. Then with a paper towel wipe some of this solvent on the remaining glue and let it sit for a couple of minutes. Then wipe it off. Very easy, quick, and takes virtually no elbow grease. The solvent is called "orange peal" ask around at some local graphics/lettering shops. Probably common knowledge in that line of work. I got mine for free. It's less than a cup in the bottom of the bottle. Enough to last me a lifetime as much as I remove a
    ny decals. Great stuff.
    lowjo Thanks this.
  10. xsetra
    xsetra Road Train Member
    5,114
    6,981
    Aug 21, 2011
    I bought my (decal remover) drill attachment from CARQUEST. I think it is made of bees wax. It goes in drill like a wire wheel. Takes all decals off leaves paint untouched. Not really any clean up to mention. I would think any store that sells auto paint would sell this wheel.
    lowjo Thanks this.
  11. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    I went to body shop supplier and they had a Dupont and a cheap wheel. Counterman said for what I wanted to do(same as you) get the cheap one. $19.00 with the mandrel and all. It went through those decals like a hot knife through butter. The wheel still has plenty of meat left on it. Those things are the answer for decal removal.
