Stop it with the high trailers!
Discussion in 'Experienced Truckers' Advice' started by Sequoia, Mar 14, 2011.
  1. Sequoia
    Sequoia Road Train Member
    2,692
    1,794
    Dec 4, 2010
    Tampa Bay, FL
    When you're disconnecting from a trailer, crank the landing gear down until both feet are firmly on the ground (and even). Then keep cranking until you hear the hissing from your air bags, letting you know pressure is being taken off the tractor. Once you hear that hissing sound (and you'll know it when you hear it) STOP CRANKING THE LANDING GEAR!
    I just swapped trailers with another driver who had the exact same truck as mine (International ProStar). When I went to connect up to the trailer he had, I could tell when I was getting ready to get underneath it that it was too high. Stopped, got out, sure enough he had overcranked the landing gear.
    The worst is when it's a high trailer and it's heavy. Good lord those are a pain to crank. I don't know how you skinny people do it. I've had to really put my weight into some of those to get them to crank. Well I guess there's low gear but that takes forever and I got places to go, things to do and people to annoy. :)
    ..and this is the part where someone will tell me that different trucks have different frame heights so it's not always the driver's fault.
    Texas-Nana and Freebird135 Thank this.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    You all are killing yourself. I always stop my landing gear about an inch from the ground and then dump my air, then pull out. Then when the next guy gets under it, the weight is off the landing gear and you don't have to fight it.
  4. Inland-Pilot
    Inland-Pilot Light Load Member
    229
    135
    Jun 23, 2010
    Jackson, Ms
    123456, Lonesome, Wargames and 2 others Thank this.
  5. Scarecrow03
    Scarecrow03 Road Train Member
    3,411
    7,443
    Sep 27, 2006
    In Your Head
    I used to do that until the dolly legs bent the five cross-members of the trailer it's attached to. Even though I'd let the bags deflate completely, the trailer had weakened to the point that it couldn't take anymore.
    Now I crank 'em down til the dolly legs are touching the ground and it starts to get tough to turn the handle. Then I get in the truck, dump the air, and ease on out. Even though I generally pull the same trailer, I deliver to a lot of Wal-Mart DC's and always have to drop the trailer in the door.
    If all you're pulling is 3 year old trailers or newer, you can get by with what you do. However, you're drastically shortening the lifespan of that trailer. Even if the trailer belongs to the company, it's our responsibility as drivers to not intentionally do things that are detrimental to the equipment we use.
    When I worked for large companies I didn't care so much, but now I realize that was the wrong attitude to have. Somewhere someone is probably cussing me or another mega-fleet driver who didn't give a rats arse about the equipment they used. Every carrier sells they're used equipment to smaller companies and/or independents.
    Logan76 and Texas-Nana Thank this.
  6. Paddington
    Paddington Medium Load Member
    454
    319
    Jul 5, 2009
    Cleveland, Ohio
    I believe CondoCruiser is right.
    The tractor should always lift the trailer.
    Therefore, you should leave about and inch of space or so before you drop so the next guy who hooks to it lifts it.
    Wargames, Wiseguywireless and Lonesome Thank this.
  7. outerspacehillbilly
    outerspacehillbilly "Instigator of the Legend"
    4,349
    2,430
    May 28, 2009
    The Who's Your State
    That's the way I've always done it too.
  8. Sequoia
    2,692
    1,794
    Dec 4, 2010
    Tampa Bay, FL
    The way I do it (as described earlier), I still dump the air bags before I'm pulling out from it, so when backing under fully inflated the trailer should still lift up some.
  9. Scarecrow03
    3,411
    7,443
    Sep 27, 2006
    In Your Head
    It still lifts up the way I do it. And when the trailer is empty the dolly legs come up off the ground an inch or so. No straining yourself to crank 'em up. When the trailer's loaded it'll come up enough to take the tension off the legs.
    Big Duker and Texas-Nana Thank this.
  10. 25(2)+2
    18,750
    45,476
    Sep 18, 2006
    the road less travelled
    Every once in a while, I'll get one that has been dropped in a bad place by the yard jockey, and it will be too high because of differences in slopes or maybe because the previous OTR guy cranked it too high. If it will lift at all, when I back under it, I hook it up and hook up the air and electrical, push in the supply knob, and do the walk around checking tires and lights. If the airbags had dumped, the trailer will lift a bit when the bags air up and that will take some weight off the landing gear, if the landing gear is pinched, the trailer will move to reduce that.
    I remember when I started that Schneider had their drivers hook up the hoses and supply air and use the trolley valve hold the brakes to hook, that would get air to the bags, too. The thing is, it didn't help the height situation with Schneider's trailers because those are all sprung on steel(the vans were, anyway). I seldom see them anymore because I haven't pulled a dry van in what seems forever.
    You need to learn to use low gear sometimes to lower a trailer enough to get it down to where you can crank it on high, sometimes, you have no choice unless you can get the yard jockey to lower it for you. If you can't crank it, you have to figure something else out, either get help, or use your imagination to come up with a solution.
  11. Lonesome
    Lonesome Mr. Sarcasm
    11,115
    22,736
    Dec 15, 2007
    Northern Indiana
    If you drop the landing gear, until you hear the suspension on the truck hissing, you're NOT going to lift the trailer with the truck when you go back under it, especially if it's loaded. Also, if you're off an inch or two, and the trailer moves sideways to line the pin up, you'll have a heluva time cranking the gear. Especially if someone locked the handle in the holder.
