Stopping on Hills/Inclines
Discussion in 'Questions From New Drivers' started by AndrewMemphis, Feb 10, 2013.
  1. AndrewMemphis
    AndrewMemphis Light Load Member
    61
    15
    Jan 5, 2013
    Southeast region
    Dear all,
    Is there a way to come to a complete stop on a hill without sliding backwards? There is one particular hill I find rather troubling, and that's at exit 161 in North Little Rock, Arkansas when you're going to the Petro or the Pilot. If you're coming East-bound down I-40, you have to stop at the ramp as it's 3-way intersection with stop signs on all three sides. One for the people leaving the Pilot/Petro, the other for people coming down west-bound I-40 and the other for people getting off the ramp coming East-bound down I-40. I have noticed that many drivers don't even come to complete stops at these signs, they seem to just put it in a very low gear such as 2nd and wait until they feel it's safe to move on. I've found that to be an effective way to prevent from sliding backwards and potentially hitting someone else, but is that legal?
  3. Powder Joints
    7,657
    7,739
    Sep 25, 2007
    Rosamond, SoCal
    No its not legal. I stop on steep inclines regular. Its part of driving. Use your trailer brake hand valve to hold the truck as you ease out the clutch. If you add throttle, go easy with it.
    AndrewMemphis and davetiow Thank this.
  4. Vaio127
    Vaio127 Bobtail Member
    Jan 9, 2013
    Technically no, and I feel this is one of those spirit of the law vs. letter of the law instances. The law dictates that you must come to a complete stop, though most people would agree that it's better to keep moving slowly and proceed cautiously when the intersection is clear rather than roll backwards and potentially hit an obstacle behind you.
  5. Powder Joints
    7,657
    7,739
    Sep 25, 2007
    Rosamond, SoCal
    This is part of driving. If you cannot start off on a hill, then you have no business behind the wheel. period. My suggestion is learn to drive. Do not run stop signs.
    unloader, Fatboy42, cc tanker and 6 others Thank this.
  6. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    Yea definitely come to a stop. EASE out of the clutch, when you feel it grab give it throttle.. Simple.
  7. terrylamar
    terrylamar Road Train Member
    1,023
    368
    Oct 8, 2006
    Austin, TX
    Your air brakes take about a second or so to release. You have plenty of time to time taking your foot off the brake and letting the clutch out. Find a place to practice with no traffic. It isn't very hard to do.
    Moosetek13 Thanks this.
  8. TripleSix
    129,326
    If you're heavy, drop it in a very low gear and come to a halt. The lower the gear, the easier it is for the clutch to pull you forward. You ease off the clutch and the brake at the same time and the clutch will pull you. You don't want to roll backwards because you will either hit someone behind you ( you know that stupid 4 wheeler that pulled 2 inches off your ICC? Yea, that idiot) or twist your driveshaft like a pretzel.
    There are quite a few drivers that will not come to a complete stop to avoid having to pull from a dead stop. I'm not going to debate the whys and why nots. The thing that we all need to know is how to control the vehicle in all situations. Sure we all like to avoid trying to pull out of a hole, but sometimes, it's unavoidable. And if you are ever HEAVY heavy, like in a heavy haul load, or a B Train, it's even more important. But your normal truck, 80000 lbs, your granny gear should be more than sufficient to pull you out of a hole.
    AndrewMemphis Thanks this.
  9. G/MAN
    G/MAN Road Train Member
    7,031
    8,622
    Sep 3, 2010
    I always come to a stop at a traffic light or stop sign. If a cop sees you running the stop sign, you will receive a ticket that is considered a "moving violation" on your MVR. If you have a problem using the clutch to pull out on an incline or hill, then you can use the hand brake, as someone else suggested. It should become easier with practice.
  10. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Just how steep is this exit that would cause you to slide backwards?Can someone post it on here?If it's that steep and don't feel safe at that piticular exit then why even take that exit.I've taken many steep exits with a warning sign before you take it.As long as you go real slow and not come barrowling down like some bad ### you should be fine.
  11. AndrewMemphis
    61
    15
    Jan 5, 2013
    Southeast region
    Thanks, I had been wondering about this. I guess I will keep practicing -- find some place that doesn't get a lot of traffic. I work between midnight and noon, so anywhere before 6 AM.. I shouldn't have to worry about too much behind me! It does always make me pretty anxious when I feel that trailer sliding backwards, haha. I just have to remind myself to relax, and I know what to do -- I just have to time it right. There was one instance where I literally had to floor the throttle to get it up the hill above 2000 RPM's after I stopped.
