Stowing load locks
Discussion in 'Experienced Truckers' Advice' started by JC1971, Jun 20, 2016.
  1. JC1971
    JC1971 Road Train Member
    2,610
    9,329
    Jul 29, 2013
    L.A.
    I just ended up with two load locks for the first time after unloading. The roof in the Cascadia isn't quite high enough to put them behind the seat. They've already fallen over once and almost hit my head while turning which I'm sure wouldn't have felt good. Any suggestions?
  3. rabbiporkchop
    9,676
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    I used to keep a couple under my bunk in a Volvo 770
  4. dutchieinquebec
    dutchieinquebec Road Train Member
    1,282
    4,863
    Sep 30, 2012
    Granby.QC
  5. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Strap them horizontally to your catwalk using rubber straps or buy a Load Lock Holder.
    I stopped using them as they take up too much room being stored on my truck and I haven't used any in over a year and now I am using Load Straps, which is the equivalent of using Load Locks.
  6. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Unless things have changed, rubber tarp straps are NOT acceptable means of securing items to your catwalk or anywhere else for that matter. Their only acceptable use is to hold a tarp that is opened up covering a load. If you want to secure anything else, it needs to have a load rating. 1" straps work great for small, light weight stuff on the catwalk. If the wrong DOT man catches you with bungees holding rolled up tarps, dunnage, load locks, or any other equipment on your truck or trailer, you can be cited for having an unsecured load. Sure, I know and you know it probably won't go anywhere...and you may go through several level 1 inspections before you get an officer who will even notice...but if he does, and feels like making a stink over it, he can (and will).
  7. 48Packard
    48Packard Ol' Two-stop Shag!
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    Never forget seeing a CRE lease op in a green FL years ago....he must've had a dozen load locks riding between the cab extenders. One end of the bunch had fallen and was precariously close to creating a real problem. I tried to get his attention, and, well...you know how that went....
    Bob Dobalina Thanks this.
  8. Allow Me.
    10,643
    12,114
    May 28, 2009
    Rancho Mirage, Ca.
    I've stored them on top of the fuel tanks parallel with the truck frame, that's if they fit depending on truck make/model.
  9. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Don't let DOT catch you with load locks inside the cab. It's against the regulation to have anything in the cab that is not your personal property with the exception of certain safety items like a fire extinguisher and that must be secured.
  10. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Cite the regulation, please.
    Chewy352, Toomanybikes, A21CAV and 3 others Thank this.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I was over weight on the trailer by 500 lbs and couldn't move the axles back due to California rules. So I took ten bags of peat moss (50 lbs each) and put them on the top bunk, put a strap across. Worked good.
