Straight pipes on DPF engines
Discussion in 'Ask An Owner Operator' started by ThePettyTruck, Jul 19, 2015.
  1. ThePettyTruck
    ThePettyTruck Bobtail Member
    10
    12
    Feb 3, 2014
    Semmes, AL
    Anyone running straights on a DPF motor? I'm curious if it's still loud or a little more mellow. I traded my 04 Freightliner Coronado in on a 15 Lonestar with a 600 Cummins and miss my straights. This thing is entirely too quiet. Thanks.
  3. rollin coal
    rollin coal Road Train Member
    13,089
    25,929
    Mar 29, 2008
    TN
    Normally larger diameter pipes tone and quieten things down but if it has a DPF on it doesn't matter what diameter pipes are on it. It will always be quiet.
    Vampire, Studebaker Hawk and Long FLD Thank this.
  4. Long FLD
    Long FLD Road Train Member
    11,433
    46,267
    Mar 4, 2015
    Straight pipes will only be for looks if you have a dpf. And you need the high dollar ones to keep them from discoloring from the heat. If it were me, I'd run a weed burner and put dummy straights on.
    Vampire and jesse0711 Thank this.
  5. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    I can't even put straights on my non DPF Acert so what I've been told
  6. Long FLD
    11,433
    46,267
    Mar 4, 2015
    You can, technically they're supposed to have the catalytic converter mufflers on them though.
  7. hawkjr
    1,652
    638
    Feb 28, 2010
    Virginia
    Do you know why that is??
  8. Long FLD
    11,433
    46,267
    Mar 4, 2015
    On the pre-dpf Acerts that was how they met the emission requirements without egr.
    whoopNride and hawkjr Thank this.
  9. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    Instead of wasting your money on straight pipes buy some testosterone pills,
    tarmadilo, flood and Tb0n3 Thank this.
  10. ThePettyTruck
    10
    12
    Feb 3, 2014
    Semmes, AL
    You can suck it there Swiftie. I don't need testosterone pills because I'm not a washed up has been like you are.
    I spoke with a guy who had a set on a 14 Pete 389 with a 500 Cummins and it wasn't loud but it wasn't as quiet as stock but I wasn't sure if he had ran a straight pipe thru the dpf filter as I forgot to ask about it.
    OlegMel Thanks this.
  11. hawkjr
    1,652
    638
    Feb 28, 2010
    Virginia
    Does the straight pipes effect the exhaust system negatively in any way on the Acert?
    Socal Xpress Thanks this.
  12. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    No, it will breath better, throttle response will improve as well, and egt's normally run cooler. Some people say they pick up a little mileage. I've had two Acerts with straights.
