Straight Truck Axle Placement?
Discussion in 'Experienced Truckers' Advice' started by JDep88, May 25, 2024.
  1. JDep88
    JDep88 Bobtail Member
    12
    4
    May 25, 2024
    Hey all,
    I'm a local delivery driver (Class A and B). About a year ago my company purchased new tandem axle straight trucks, but someone didn't do their homework and when fully loaded they are overweight on the front. Their solution was to place pallets in the front of the box to fill space and keep the front axle under weight. Recently they have began moving the rear axles forward to better balance the weight. But they are moving them very far forward and we have just recently had several drivers clip parked vehicles with tail swing. Several other drivers have complained about excess tail swing and not being able to get into alleys and driveways since the axles have been moved. Is there a limit on how far away from the tail of the truck the rear axles can be? The only info I've been able to find relates to combination vehicles. Thanks for any info.
  3. MACK E-6
    49,728
    234,911
    Tail swing is easier to manage on a straight truck, but I still hate it.
    I’d personally rather have had the steer beefed up.
    W923 Thanks this.
  4. Numb
    Numb Crusty Curmudgeon
    4,234
    9,938
    Jan 30, 2012
    Charlotte, N.Carolina
    a straight truck with movable axles?
  5. mslashbar
    mslashbar Medium Load Member
    602
    813
    Jul 22, 2009
    elizabeth,co
    normal placement is 2/3 of the box ahead of center of axle, and 1/3 behind
  6. MACK E-6
    49,728
    234,911
    I think he either means they’re having a shop do it or changing the specs on trucks they order.
    Numb Thanks this.
  7. AModelCat
    161,612
    How much overweight up front? Sounds like someone should have spec'd a heavier steer axle.
    W923 Thanks this.
  8. JDep88
    12
    4
    May 25, 2024
    They have been going to the shop a few at a time and having the tandems moved forward.
    Numb Thanks this.
  9. JDep88
    12
    4
    May 25, 2024
    That is about where they were when ordered. Now they have almost a 50/50 split. Is there regulation on how far forward they are allowed to be? Or as long as the truck can pass the scale it doesn't matter?
  10. JDep88
    12
    4
    May 25, 2024
    I'm not sure on the number. It was some corporate dummy that doesn't understand the actual job. They bought longer trucks to load us with more cases, but joke was on them because we had to burn the first 4 feet of the box because of weight. Trucks ended up being shorter because of wasted space. Now I guess they want that space back, and a bunch of guys are getting mad. I said I'd look into if their adjustments were legal amd that's why I'm asking. I cant find any info on regulations of axle placement for straight trucks.
  11. Hammer166
    7,572
    27,594
    Aug 18, 2007
    ~8600+' and loving it!
    It won't be in FMCSA regs, at least not that I remember ever running across. Do some googling in FMVSS.
    JDep88 Thanks this.
