Strange clicking/tapping sound coming from under driver side
Discussion in 'Experienced Truckers' Advice' started by rpad139, Feb 10, 2017.
  1. rpad139
    rpad139 Heavy Load Member
    887
    564
    Jan 9, 2014
    Nevada
    There is a strange clicking tapping sound coming from somewhere under my side outside the truck. Only hear it when the truck is moving and gets slightly louder when I make a left turn.
    I checked all the steer and drive tires to check for any impaled stuck objects. Checked under the truck for dangling loose hoses, wires, belts etc... did air brake test. Checked springs, bolts, etc...tried everything to the best of my knowledge.
    Truck runs fine though on the interstate...no shaking or rough handling.
    Let me know if you guys have an idea what the problem might be. thanks
  3. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Can you only hear it with window down or does noise seem to resonate through firewall?
    Does it match road speed or engine rpm? Does the sound fluctuate in and out at given attitude? What year/make truck are we talking about?
    Anything wrapped around drive shaft?
    G13Tomcat Thanks this.
  4. rpad139
    887
    564
    Jan 9, 2014
    Nevada
    This is a 2016 Volvo vnl 670 Detroit engine. Only hear it with the window down. Seems like it makes a clicking sound with every tire rotation.
  5. rpad139
    887
    564
    Jan 9, 2014
    Nevada
    Maybe a wheel bearing? I'm not too sure. But hoping I can learn from this.
  6. STexan
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    And you've inspected all tires all the way around for a rock or bolt or piece of tire chain, and found nothing? [which iseems to be the issue based on what I'm reading]
    Do you have Cross-Fire system on drives?
    Does the sound change upon brake application while still rolling?
    rpad139 Thanks this.
  7. rpad139
    887
    564
    Jan 9, 2014
    Nevada
    Still hear the sound when brakes are applied down the road. I have checked all tires pretty good. Going try and find a way to get under the truck to take a harder look.
  8. Ridgeline
    22,603
    120,016
    Bring it to a shop and have them look at it before you lose a wheel or lose your brakes.
    x1Heavy and rpad139 Thank this.
  9. kemosabi49
    10,901
    47,287
    Jan 13, 2013
    SW Arkansas
    Ridgeline is right. A shop can jack the truck up and tell if a bearing is loose. Also a loose lug nut will sometime make a tapping sound.
  10. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    Did you check to make sure the midget mechanic wasn't trapped?
    LoneCowboy and Chewy352 Thank this.
  11. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,001
    Jan 9, 2012
    glasgow ky
    Gremlin maybe?
