I have been drug into a tug of war within my company concerning the twisting of straps on a load to prevent damage to cargo (shingles to be exact). A lot of the drivers twist their straps to prevent damage from over tightening of the straps. And our boss keeps telling us that according to D.O.T you are not allowed to do so. Can anyone shed some light on this subject.
On a side note I do not like to have my straps twisted. I think it looks much cleaner and neater to keep them straight and uniform.
Strap twisting on a flatbed!
Discussion in 'Flatbed Trucking Forum' started by Trckrh, May 10, 2012.
Page 1 of 6
We put a half twist in ours to keep them from "vibrating" in the wind.
Hanadarko, Mommas_money_maker, gator21 and 6 others Thank this. -
Personally, i twist them on some loads, others I don't never had a problem with DOT either way. Some DOT prefer them not flapping by twisting them though, but all of that is according to the famous grapevine... Wish I could help more. The regs don't say you can't, I don't think.
It depended on the load I had. If it was to the limit of the length of strap, than I most often would put a twist in the strap.
With shingles, I never found that a twist in the strap did any good. -
Thanks for the input. I have never found twisting them to help much either. But our boss is insistant that it is written in the D.O.T rule book. I really just want some one to tell me where it is in the book if it's in there cause I am tired of being the middle man.
But again thanks greatly for the input. -
SO pull out your little green book, and look it up.
I hate twisted straps, I prefer with my shingle loads to use my Veeboards plastic corner protectors and tigthen them enough so there is no movement in the straps when your rolling down the road
Kubota, I was the same way. Asphalt shingles, I would put on the edge protectors and tighten the snot out of the straps. Never had a worry about those loads moving any.
However, there were some loads of cedar shingles, that when unbroken (onto separate pallets) could stand 7+ feet tall off the deck of the truck.
I had to twist the strap to help prevent it from loosening soo much. Course, I would also drive slower, and take the corners slower as well.dannythetrucker Thanks this. -
I have always made sure my straps were straight, I think it looks cleaner. I did a little search and found this, From a spokesman from Kinedyne....
You can read the whole article >here.<bullhead, BigBadBill, Trckrh and 1 other person Thank this. -
If you haul insulation or something like that wrapped in plastic it is a good idea to put a half twist in the strap. When a strap is straight it slaps the product and can tear plastic wrap, paper, etc... , when a strap has a twist in it rather than slapping the vibration flows out through the ends like a guitar string, it just glances against the product. Irrelevent to asphalt shingles though I would think. Just put your vee-boards on and crank em down.
Page 1 of 6
