Strobe lights wired to turn signals problem Maxxima M20384YCL
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rshakin, Sep 17, 2018.
  1. rshakin
    rshakin Bobtail Member
    20
    Hey Everyone
    So i decided to wire up some yellow strobes in addition to my trailer turn signals. A little about my setup
    2007 Peterbuilt Car Hauler Boydstun 9100ST 9 Car, I am having some feedback issues from what I can tell, I wired the strobes directly to the hot circut that turns the flashers on, so in essence when i turn on the blinkers or hazzards both the regular turn signal goes on and the strobe flashes, and everything works great, but as soon as i turn on the clearance lights the turn signals work but strobes stop working all together, also when the clearance lights are off you can see just a faint glimmer of strobe pattern in all the turn signal and stop lights.... any ideas what gives... ?
  3. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    Usually bad grounds cause this and power through other light circuits with back feed through the filaments to find a good ground on other lights causing the faint glow.
