Struggles to start in cold 2013 Freightliner Cascadia
Discussion in 'Ask An Owner Operator' started by Eric5220, Jan 21, 2025.
  1. Eric5220
    Eric5220 Light Load Member
    72
    25
    Mar 23, 2021
    My truck always gives me a hard time to start when the weathers is 25 or lower . I have to spray it with starter fluid to start it . Today it’s 5 degrees and I’m jumping the truck what can I do to fix this . I see other truckers come in start they truck easily but not my truck dd13 engine let me know any suggestions
  3. Big Road Skateboard
    6,721
    37,838
    May 2, 2021
    Could need batteries, a starter, compression...
    Is it turning over slow? Is it your truck?
  4. Eric5220
    72
    25
    Mar 23, 2021
    I cranks feels like it’s weak and needs a jump but even with new batteries I had this problem every winter . Last two winters I replaced them in October
  5. idriveaholden
    idriveaholden Super Heavy Hauler
    707
    2,228
    Mar 14, 2018
    Try it with the block heater plugged in once and see how it does maybe you can narrow it down
    wis bang and Opendeckin Thank this.
  6. Allow Me.
    10,732
    12,448
    May 28, 2009
    Rancho Mirage, Ca.
    How long is it sitting ? Overnight or what ?
  7. 77fib77
    77fib77 Road Train Member
    11,370
    74,048
    Jul 7, 2010
    St Louis
    Get a hair dryer or heat gun. Heat up the intake manifold going into the engine. The hotter the intake air the better the diesel atomizes
  8. Kenworth6969
    2,979
    9,329
    Jul 3, 2020
    I had an old freightshaker not too long ago, when it was super cold i just left it running.
    If it had to be off I carried this around.
    It saved me many times.
    Eric5220 Thanks this.
  9. AModelCat
    161,630
    If you need a boost at those temperatures then you've got battery or charging problems. No reason you shouldn't be able to spin that engine over for a couple minutes on 4 good batteries (not steady cranking, 20-30 seconds, cool off for a couple mins and repeat).
