Stryker 655 problems
Discussion in 'CB Radio Forum' started by Dirtymartini15x, Apr 3, 2017.
  1. Dirtymartini15x
    Dirtymartini15x Light Load Member
    180
    114
    Oct 18, 2016
    Ok guys so as I've said in some of the other threads I have a 4 year old Stryker 655 that I've only used for about six months total. On Friday last week I got a different truck at work, swapped everything over from the old truck and checked the swr it was 1.3:1, then later that day it shoots up to 3:1 and I noticed that the variable power is either all the way down with the knob turned to the left, or it goes right to full power as soon as you move it off the far left position. The colors on the faceplate also change colors in different locations on it's own, and the channel selector is lose.
    Today I ran my 8awg wire for my 98vhp to see how that radio faired in the truck since when I tested the swr today it showed 2.5:1 with the stryker. Hooked up the 98 and the needle barely wiggles all across the band. So it's definitely a radio problem with the stryker. Any idea's what it could be before I send it out to get fixed?
  3. Ridgeline
    22,177
    113,816
    What?
    Send it out to be fixed, it is obvious something wrong with the radio.
    By the way you using an external meter?
    I assume not but I maybe wrong.
  4. Dirtymartini15x
    180
    114
    Oct 18, 2016
    After reading my post again, it seems pretty clear to me what I was saying. And yes I used an external swr meter, it reads exactly the same as my 98vhp. I was just posting here in case anyone else has had similar issues so I can be prepared for what it should take to repair the radio.
  5. Ridgeline
    22,177
    113,816
    It sounds like there is something internal to the radio, example is the colors changing and the power going up, maybe a ground is loose within the radio.
    bored silly and Dirtymartini15x Thank this.
  6. Dirtymartini15x
    180
    114
    Oct 18, 2016
    That's what I was thinking but I wasn't sure if one of the drivers going bad could give me the the high swr and variable power issue. I think the colors, and the channel knob are a related problem.
  7. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    I would love to confirm this with an MFJ analyzer.
  8. Diesel Dave
    8,563
    23,801
    Jan 20, 2010
    Hesperia, Ca.
    Or you can send it to fine tune cb shop. $100.00 on shipping for both ways plus what it will cost to to fix it. By then you will be better of buying a new one. ( yes, it was a sarcastic comment)
  9. Dirtymartini15x
    180
    114
    Oct 18, 2016
    Im working in borrowing one. But both of my swr meters are accurate according to my mobile setup which uses a bird dual line section to measure forward and reflect.
  10. Hambone88
    Hambone88 Bobtail Member
    I just bought a 655 it was already tuned before I put it in the truck now I have less than 1.5 swr but I can't receive anything and all.i hear is static when it appears to be trying to receive any help is appreciated.
  11. bored silly
    bored silly Road Train Member
    2,714
    656
    Jul 1, 2016
    I use or have to build another power cord with 4ga. Welding cable. Anderson connecter to the radio and a inline fuse down at the power source the battery. Don't trust 8ga. To give me full power to a 300 watt or 400 watt radio. But that's just my opinion one of many on here....
