Stryker 955 conversion help...
Discussion in 'CB Radio Forum' started by BiggyJ, Apr 19, 2016.
  1. BiggyJ
    BiggyJ Bobtail Member
    Apr 19, 2016
    Hi guys...
    Just received my Stryker 955 in the mail today and went to do the frequency conversion to 11 meters and noticed that the board in my unit is different than the one at CBTricks and at CBRadioMagizine. So I am not sure which component to remove. Surely don't want to pull the wrong one off the board.
    I took some pics of the area that is simular to that on the two sites I mentioned above and posted them here http://jaxehost.com/radio3/
    They are the same area but I thought that one of them may be more easily viewable to you.
    Can someone help me identify the correct resistor to remove?
    The board has it's own little arrow on it pointing to a resistor. I'm wondering if maybe that's a little help from the manufacturer?
    I sure appreciate you guys and all the help you offer everyone.
    Thank you,
    John
  3. Evvy Thomas
    Evvy Thomas Light Load Member
    214
    113
    Apr 11, 2015
    NW Ohio
    In my (very humble) opinion you would be best off taking it to a reputable shop and having them do the conversion and alignment for the few dollars they may charge to be sure it's done right.
    A quick image search tells me that yes, that arrow is a hint. But again, do not take my word as gospel.
    Ougigoug and rabbiporkchop Thank this.
  4. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
  5. mike5511
    mike5511 Road Train Member
    3,140
    1,523
    May 15, 2011
    NW Arkansas
    Your receive needs to be tuned to 11 meters for best results.
  6. BiggyJ
    Apr 19, 2016
    Thanks guys...
    Evvy Thomas Thanks this.
  7. kelly4221
    kelly4221 Bobtail Member
    Were you able to get your radio converted
  8. slim6596
    slim6596 Medium Load Member
    621
    722
    Dec 1, 2015
    FYI, I was told by Stryker's customer service that this was not necessary. I specifically asked about receiver returning after conversion to CB band.
    Still 0lanning on getting my radio to someone who can check it out and do it right, though.
  9. Ridgeline
    22,266
    114,778
    It is a broadband front end on the radio, leaves a lot to be desired and needs tuning.
    mike5511 and slim6596 Thank this.
