Thnx in advance fellas... my Freightliner sounds like a 2 stroke. All gauges and oils look fine. Loud popping sound coming from the motor/exhaust. The innercooler tubes feels really rough with the popping sound. The motor revs fine with no hesitation. Just popping sound gets louder. Im thinking a head issue. Im hoping some of you can point me in the direction of a good honest mechanic in the Columbus ohio area able to tackle this problem. I can go the dealer route but they wont even look at it till late in the week.. Your help is great appreciated.
Stuck in Groveport, OH Caterpillar C12 with an engine problem....
Discussion in 'Trucks [ Eighteen Wheelers ]' started by freedomisntfree, Sep 9, 2012.
freedomisntfree Thanks this.
Yes sir u may be right .. im heading out to search for a spot in a few minutes i will definately go see them.
What is it doing? Is it popping or something?
Yes its popping..... i put it in a mom and pop shop close by... mechanics are not very good at diagnosingg... i been here a whole week now. After pulling valve covers and probingg around there mechanic noticed that the turbo pressure actuator deal... (i forget its real name sorry) was frozen shut. Then i asked, well if thats the case why dont u disconnect it and operate it manually while engine is running and see if that truly is the problem. Then i asked if he ruled out the innercooler because motor seemed to gasp for air. Turbo spools fine. I let them do their job. When i returned the turbo was out, exhaust manifold off .broken manifold bolt stuck in the block. I believe the problem is in the head or innercooler, mechanics believe the problem s the turbo actuator. Any thoughts? While it was running the innercooler hoses were making like a suction action
sounds like it lost a cam roller (common on the c12)
