Stuck injectors?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Fusterated lowmax owner, Oct 5, 2016.
  1. Fusterated lowmax owner
    Fusterated lowmax owner Bobtail Member
    6
    Is it possible that all injectors are stuck after truck has been sitting for 5 years? Or could it be a ECM
  3. 25(2)+2
    18,750
    45,476
    Sep 18, 2006
    the road less travelled
    What kind of engine?
  4. AModelCat
    158,564
    What's it doing?
  5. Fusterated lowmax owner
    6
    My tragic story.....I have a 2004 WS Series 60 , (there should be a lemon act in Canada) after 3 motor jobs on this baby , and many hours of fighting with Detroit Engines, and the garage that did the work , Detroit relented and put in a new motor (thanks Detroit ) drove the truck home , pulled 1 load and bam truck down again! Went out and bought a 379 Pete so I could fund the WS! Parked the ws for 5 years and now they are telling me ALL the injectors are stuck, truck was parked right after the motor job. I know I had problems with the ECM wiring before the truck was parked , but garage is telling me its showing no codes for ecm. I just want some feed back from anyone that can offer,feeling very fusterated with this truck!
  6. AModelCat
    158,564
    Again, what's the truck doing (or not doing)?
    25(2)+2 Thanks this.
  7. Fusterated lowmax owner
    6
    It wont start. New batteries, and fuel. Mechanic says it pushes fuel up to injectors but truck will not fire.
  8. Fusterated lowmax owner
    6
    They say they had it on the computer and it is not throwing any code to indicate ecm, so they told me all injectors are stuck, took them a half hour to make this diagnoses. I do not know a lot about how this all works , but I feel being a female they will just about tell me anything cause I wouldn't know the difference.Just not too sure which direction I should go? Put the 5000 grand in that they said it would cost, or move it to another garage. Thanks
  9. AModelCat
    158,564
    @swaan seems very knowledgable about the Series 60's.
    I can't see all 6 being toast. I'm thinking maybe there's a condition that's not being met. Something like no speed sensor or cam position signal.
  10. Heavyd
    Heavyd Road Train Member
    7,769
    6,209
    Feb 4, 2009
    Yes they can be all stuck. The fuel will varnish inside the injector and get gummy.
  11. Fusterated lowmax owner
    6
    If that is the case do I have to replace them all with new or is there a way to clean the existing ones?
