stuck on side of road right now
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by pete159, Sep 23, 2023.
  1. pete159
    pete159 Light Load Member
    108
    70
    Dec 6, 2008
    mississauga
    I had issues starting the truck It will not turn over.
    Sometimes tightening the batteries helped.
    The mechanic fixed the battery shut off valve and set everything was fine
    Truck would not start for 2 hours today.. now it's starting but I'm getting every warning message in the book.
    Gas pedal does nothing truck will not idle and shuts off after 5 minutes. I'm literally getting every possible warning message as well as all the lights are on.
    It's a Volvo 760 withCummings ISX engine and Eaton Fuller automatic
    Flat Earth Trucker and austinmike Thank this.
  3. loudtom
    loudtom Road Train Member
    1,717
    2,805
    Aug 26, 2016
    Clean all of your grounds, test all of your batteries, check all of your cable ends for corrosion, check the maxi fuse coming off of the positive cable for the battery. If you can't find an issue after that, it'll be better to get it in to a shop than try to fix it on the side of the road. If it's in the wiring harness somewhere, it is time consuming to unwrap and find it. If it's an ECM issue, it will need to be reprogrammed if you need a new one.
    I had an issue with losing all lights and power when hitting bumps, which ended up being the maxi fuse. Voltage was also fluctuating on the dash from 12.6-13.6V. Moving the cables around and tightening the battery would seem to fix it, but any sort of bump would cause power loss again.
  4. Dave_in_AZ
    414,741
    Grounds. Very possible bad interlink between batteries.
    Something is broken in one of the interlinks, a buss, or if they are all cables, one is hanging on by a thread at a connecter.
    Start with the one that goes from the truck to the battery box.
    You need to take them all apart. Visual won't do it.
