Hello all. I am a stuntman in the tv/film industry. I hold a Class A CDL and at 1 time before getting into stunts, I drove for a living for about 4 years. Obviously I'm not in trucks every day and just have a quick question or two.
I have an upcoming stunt, very simple, but I just want to gather as much info as possible before hand as I don't really receive a lot of info prior to the day of work, nor do I get much time to familiarize myself with the truck.
Question is, on trucks with the ability to split gears, if I'm running empty do I still need to split each gear or can I run through the gears normally without splitting gears?
Also I attached pictures of the truck. A Kenworth. Based on the picture (sorry for the poor quality) any idea what transmission will be in there?![]()
Stuntman with a couple of questions
Discussion in 'Questions From New Drivers' started by FallGuy44, May 4, 2018.
Page 1 of 4
If I was running empty, I would only spilt the last two gears at the most. I would guess that truck has a 13 speed, so just split 8th and 9th. If on flat ground, just 9th would be fine.
justcarhaulin, jammer910Z, Lepton1 and 1 other person Thank this. -
You can shift without splitting; you can even skip gears if bobtail.
It probably has either a 10-speed or 13, but could be 9, 18, auto...Grubby Thanks this. -
Thanks for the quick replies. Appreciate it.
Don't mean to insult you, but just to be sure that we are talking about the same thing, you know the difference between a splitter and a range selector, right?
That looks like a mid 2000s ex-Palmentere Brothers truck to me. Not sure if they run autos or manuals.
FallGuy44 Thanks this. -
Lepton1 Thanks this.
And yes, you can skip it. Basically run it like a 9 speed.
Unless it's a super ten, then don't skip.Bob Dobalina Thanks this. -
Don't you have a t cynical advisor on the set or one that can be tapped?
Page 1 of 4
