stupid hazmat qesution
Discussion in 'Questions From New Drivers' started by chris886, Dec 16, 2014.
  1. chris886
    chris886 Medium Load Member
    531
    286
    Aug 22, 2013
    Chicago, IL
    Diesel fuel is considered hazmat. If you have over 1000lbs of hazmat you need placards. If a gallon of diesel weighs about 7lbs then 143 gallons would be 1000lbs. So why is it not considered hazmat if you have 143 gallons of diesel in your fuel tanks but it is a hazmat load if you have 143 gallons in a tank in the trailer?
  3. Giggles the Original
    Giggles the Original Road Train Member
    subscribing to see the answers that will be posted....
    Klleetrucking Thanks this.
  4. stabob
    stabob Heavy Load Member
    862
    483
    May 25, 2011
    Sebring Fl
    Fuel in your tanks is not cargo. No bill of laden no hazmat.
    chris886 Thanks this.
  5. ineedajob
    ineedajob Light Load Member
    232
    191
    Oct 18, 2014
    I'm wondering the same but not about the fuel but about the methane that I'll be transporting in the cab after I eat some Chinese food. Thanks in advance for any suggestions.
    Skydivedavec, Vilhiem and Blu_Ogre Thank this.
  6. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Beano... lots of it.
    Skydivedavec Thanks this.
  7. Cat sdp
    Cat sdp . .
    21,055
    73,822
    Apr 8, 2012
    Orion's Belt
    You don't need placards for your fuel tanks....
    But if you crash and rip open the fuel tanks and put maybe 2-300 gallons of fuel on the ground or worse in the water.....you'll be horrified by the bill for the clean up .
    G.Anthony Thanks this.
  8. chris886
    531
    286
    Aug 22, 2013
    Chicago, IL
    I know you don't need placards. But the logic of the law makes no sence. Is the diesel somehow less hazardous in your fuel tank then in your trailer. Just about every truck has over 1000 lbs of fuel and it is not seen as a hazard, put the same amount of fuel in the trailer all the sudden you need pplacards, and an endorsement to drive it.
  9. JoeBear
    JoeBear Light Load Member
    103
    46
    Jul 18, 2014
    Houston, Tx
    Refer to this.
    ncmickey and stabob Thank this.
  10. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Because its cargo. Emergency response and public need to know the danger level of cargo in case of emergency. It would be common knowledge there'd be diesel in the fuel tank of a semi, hence no placards.
  11. chris886
    531
    286
    Aug 22, 2013
    Chicago, IL
    Makes sence
