Stupid incident to my truck hoping I want get fired
Discussion in 'Experienced Truckers' Advice' started by truckerlife74, Apr 23, 2013.
  1. truckerlife74
    truckerlife74 Medium Load Member
    369
    344
    Nov 7, 2012
    Charlotte nc
    I had a stupid incident don't know if I am the first but I am new to trucking and I believe I am going to get terminated since this my 2nd incident. Long story short I forgot to uncouple and damage the glad hands and hoses I was told to take it to freightliner which I have done but the stupidest of this I am so ashame, from the experience how will they report this on my dac, my first incident was a backing at truckstop a month ago only 4 months in and my teammate quit on me 2 months ago
  3. QuietMike
    QuietMike Medium Load Member
    371
    165
    Oct 21, 2009
    NE Ohio
    I heard it really depends on the carrier. At Roehl I ran over a guard rail in July of 2011 then in December I hit a lightpole and a parked van. Nothing happened to me and my screw ups were worse than yours imo.
    pattyj Thanks this.
  4. Giggles the Original
    Giggles the Original Road Train Member
    i personally havent done it...but i am sure you arent the only one...to drop a trailer and forget to uncouple ur lines.....
    what happened with your backing incident??
    and your teammate quitting shouldnt have anything to do with you....
  5. rocknsand
    rocknsand Medium Load Member
    563
    256
    Dec 28, 2007
    Tonganoxie, KS
    Sheet happens, it happened to me once. Now I have a sequence that I always follow, unhook glad hands, pull pin, and crank down landing gear, always in that sequence. If I have a loaded trailer and it had a trailer bag dump, I dump bags first. This way you get it fixed in your brain and a good work habit is developed. I drive a day cab so I also look out the back window just to make sure. Only did it once and had the mechanic fix it, no big deal. And we don't use DAC.
  6. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    Well the hoses is not a costly or critical damage its actually a 15min fix. A lot of guys carry extra pair of hoses because it happens. It happened to me on my training phase 4.5 yrs ago also but never again since then. A good learner learns from other peoples mistakes and when it does happen it only takes a good learner one time for it to never happen again. Good luck and pay attention driver.
  7. thedrifter
    thedrifter Medium Load Member
    522
    263
    May 23, 2010
    portland or.
    Offer to pay for the lines. Or buy them and fiz them. If the cab wasnt hurt. It would be up to you if you told anyone
  8. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    I've done that before. Didn't do any damage but I did feel like a moron.
    LaBubba, CertifiedSweetie and Lonesome Thank this.
  9. Elendil
    Elendil Heavy Load Member
    921
    626
    Mar 27, 2011
    Ottawa, IL
    Yep. Been there. Done that.
    Having a routine is important. I follow the same sequence every time. I exclusively pull doubles so I have 3 sets of air lines, 2 sets of landing gear, and 2 pins so having a routine is important.
  10. formertaxidriver
    formertaxidriver Heavy Load Member
    767
    375
    Jan 22, 2008
    Aiea, HI
    Admit your mistake, be upfront with your responsibility. Let them know what you have learned and the improvement the incident has created in you. Slow down! As others have said, have a regular routine when coupling or uncoupling. The time I forgot, the gladhands slipped off the trailer and hit the back of the cab like a gunshot! It left a mark....
    Big Don Thanks this.
  11. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    What stumped me was I wasn't expecting to drop my trailer at this customer. Threw me off a bit.
