Stupid rookie question
Discussion in 'Questions From New Drivers' started by Jwhis, May 18, 2018.
  1. Jwhis
    Jwhis Heavy Load Member
    862
    1,356
    Jan 17, 2018
    is a non functional air horn a DOT violation?
  3. INRUT
    INRUT Medium Load Member
    532
    1,899
    Aug 21, 2016
    Yes
    Lav-25 and Lepton1 Thank this.
  4. firemedic2816
    firemedic2816 Road Train Member
    1,077
    1,489
    May 14, 2016
    Walton Kentucky
    Everything is LEGAL....UNTIL YOU get caught....But yes A HORN not necessarily AIR HORN
    393.81 Horn.
    Every bus, truck, truck-tractor, and every driven motor vehicle in driveaway-towaway operations shall be equipped with a horn and actuating elements which shall be in such condition as to give an adequate and reliable warning signal.
    Lonesome Thanks this.
  5. Jwhis
    862
    1,356
    Jan 17, 2018
    For some reason I never bothered to check it and only found out when I tried to honk at someone
    BUMBACLADWAR and Lepton1 Thank this.
  6. TankerYankr
    TankerYankr Medium Load Member
    303
    470
    Jan 16, 2010
    Central US
    No, it's not.
    The regs state that you must have working horn, they do not specify which has to work.
    If only your city horn or , only your air horn works, as long one works you're good to go.
    Hulld, 12 ga and austinmike Thank this.
  7. Jwhis
    862
    1,356
    Jan 17, 2018
    The reg horn works but not the air horn. Guess I’ll put it on my pre trip tomorrow
  8. firemedic2816
    1,077
    1,489
    May 14, 2016
    Walton Kentucky
  9. firemedic2816
    1,077
    1,489
    May 14, 2016
    Walton Kentucky
    BTW the only STUPID question is the one you fail to ask....and it only becomes a MISTAKE if you fail to learn from it, other wise it's a learning opportunity
    Lepton1, 201, jammer910Z and 2 others Thank this.
  10. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    Wrong. Try again sweetheart
  11. INRUT
    532
    1,899
    Aug 21, 2016
    You can get an attorney & fight it. TX will tag you. Fact !! Sweetheart
