STURDY-LITE LOADING RAMP
Discussion in 'Flatbed Trucking Forum' started by chriscol, Jun 15, 2017.
  1. chriscol
    chriscol Bobtail Member
    I am a newbie entering the step deck experience.
    I am shopping around for loading ramps and all the accessories .
    So far I have two options
    option 1 discountramps.com
    Step Deck Trailer Ramps & Load Leveler Combo Kits
    2 Bunk Load Leveler / Modular Ramp Kit Includes:
    (4) 8' x 20" aluminum ramps with pin-on ends
    (2) Adjustable lower ramp support stands (18"-24")
    (4) Stake pockets supports for load levelers
    (6) Lumber securing clips
    as well i am getting attaching hanger brackets for loading ramps and ramp stands
    discount ramps also offer 8' x18" aluminum ramps same load rate 23 500 lbs per axle.
    option 2 sturdy lite
    Trailer Loading Ramp Master Kit 16' x 18" 25K Capacity - Trailer Loading Ramps - Trailer Parts
    Kit Includes the following:
    (4) 8' x 18" aluminum ramps with pin-on ends
    (1) Loading Ramp to Load Leveler Conversion Kit
    (1) Under Trailer Storage for 4 Ramps
    (1) Under Trailer Storage for 2 Ramp Stands
    (2) 36" Aluminum Ramp Attaching Brackets
    Made in USA
    ramp load ratio 25000 lbs per axle
    let me know what you think
    What is the quality of this products?
    Anybody using it?
    Any help will be gladly appreciate it.
    Thank you in advance
  3. zinita17601
    zinita17601 Road Train Member
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    I have discount ramps 23k rated ramps,very good product but imo 23k rating is overkill.
  4. cke
    cke Road Train Member
    5,866
    71,942
    Aug 4, 2013
    Colfax Wi
    @Hurst
    Hurst and 4mer trucker Thank this.
  5. chriscol
    Anybody using Sturdy Lite loading ramps?
    Thank you in advance for the help.
    Appreciate your answer
    zinita17601
  6. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Yes. Just bought a step with Sturdy Lite ramps. Used them a couple of times worked fine. They are rated at 25k per axle. No negative comments, but then I have never used another brand to compare.
  7. old iron
    old iron Road Train Member
    1,126
    19,701
    Feb 19, 2011
    Northern Wi
    I've got a pair of the 8' ramps/load levelers from discount ramp.
    No complaints so far.
    They're a stand up company in my book.
    I picked them up direct at the factory and it wasn't till I got home when I realized I was missing two of the stakes for load leveling. They overnighted them with no questions asked.
    From what I've seen, a set of ramps will take more abuse than a trailer will !!!!o_O
    Opendeck, snowman_w900, cke and 5 others Thank this.
  8. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    No experience with any other ramp kit besides the HD Ramps kit. I bought mine through Superior Trailers in OKC, OK.
    Mine are rated 23,500 lbs each piece for a combined supported gross weight of 47,000 lbs. Most I have ever personally loaded on them was a 44k grader.
    Ramps themselves will take a lot of abuse.
    This is a Komatsu D61. 42k lbs. I've moved approx 19 or 20 of these with out issue.
    Just a suggestion. HD Ramps sells a brace stand that goes below the rear DOT bumper. I did not have one at the time of this pic. I do now and it makes a world of difference when loading heavy up the ramps.
    Hurst
    Michael H and cke Thank this.
  9. seth Pivarnik
    seth Pivarnik Light Load Member
    104
    Nov 7, 2015
    Have you ever had an issue with metal dozer or excavator tracks messing up the aluminum ramps??
  10. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Yes.
    Excavators not so much. But dozers with tall cleats on the tracks will damage the small cross pieces that give traction.
    Figure at least one of the ramps will need some kind of repair to the cross pieces after every 10 - 15 larger dozers that travel on them. Minor repair,.. $25 - $40 for a quick weld depending on how bad they want to bend you over.
    Have to be careful,.. not everyone can weld aluminum properly. Easy to burn through and melt them. You have to then become a prick and get them to fabricate a new piece with out additional cost.
    Hurst
    seth Pivarnik Thanks this.
  11. seth Pivarnik
    104
    Nov 7, 2015
    Okay thank you for response I just got a set of ramps and was wondering if I should just stick to tire/rubber tracked equipment so I didn't tear them up.
