sunroof seal
Discussion in 'Kenworth Forum' started by rollin coal, Aug 1, 2013.
  1. rollin coal
    rollin coal Road Train Member
    13,280
    26,776
    Mar 29, 2008
    TN
    Is it just a fact of life that sunroofs in KW's leak in the rain? How much fun are they to replace and how highly $$$$$$ does KW parts desk think of them?
  3. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    I dunno Rollin', but I drove one T600 for about a year and a half with a sunroof and yes, it leaked.
  4. rollin coal
    13,280
    26,776
    Mar 29, 2008
    TN
    It's almost comical in a good downpour except for the fact the water pours on me :biggrin_2552: Had the truck for over 4 years now, it's always leaked but now much worse.
  5. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    Go get you a disposable Turkey Roaster at Wally World with some skateboard bungees with a drainage tubing of some sort, :biggrin_2559: and hook up a drainage system and drop it down through the boot where the stick is! Just don't bump it when you are headed back for a nap!
  6. rollin coal
    13,280
    26,776
    Mar 29, 2008
    TN
    It could be dual use also as a urinal???? :biggrin_25523: Never stop for pi$$ breaks!! That'll never work the cab is too cramped :biggrin_25523:
    RedForeman Thanks this.
  7. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,138
    Jan 30, 2011
    No sunroof in mine, but the seal between the cab and sleeper was leaking pretty bad when I got it. A tube of clear silicone (caulking tube that is, from Home Depot) dried that right up. I went around the problem areas lifting up the outer seal with a putty knife or screwdriver and pumping the silicone down into the gap. I suppose you could do the same with the sunroof if it has the same sort of rubber gasket as the front facing glass in the roof of the sleeper.
    rollin coal, fr8te_sh8ker and truckon Thank this.
  8. RedForeman
    4,875
    22,138
    Jan 30, 2011
    Naw, you'd just need good aim and a strong enough stream to hit the little hole in the turkey baster up there next to the sunroof.
    :biggrin_25525:
    rollin coal Thanks this.
  9. Bovinemoovers
    Bovinemoovers Bobtail Member
    26
    Oct 30, 2012
    If the seal is not torn anywhere then rub brake fluid on it. It will swell the rubber out like new. My grandmothers Buick leaked around the back door and someone told her to do this. I told her she was crazy but it worked. Actually tightened it up till you had to pull on the door pretty good to get it open. Was sealed that good.
  10. rollin coal
    13,280
    26,776
    Mar 29, 2008
    TN
    I'll give a try and see.
  11. 195Taildragger
    195Taildragger Bobtail Member
    19
    Nov 16, 2012
    SE, KS
    Mine leaked as well, but I discovered that my hinges and the locking handle were worn and not pulling the window down tight enough to make a good seal. I did a google search for the the make of the window and parts. Found an outfit on the east coast that got the hinges and handle parts for about $120 shipped to the house. Fixed the problem, now i can go through the truck wash without a rain suit. Hope this helps, when I get home I will see about getting their name and number.
