Super 10 advice
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Hype6477, Apr 27, 2018.
  1. Hype6477
    Hype6477 Light Load Member
    230
    99
    Jun 19, 2015
    Socal
    I'm going to be driving my friends super 10, what should I know. I never driven one before but I pulled an end dump for a couple years.
  3. Woodchuck88
    Woodchuck88 Medium Load Member
    553
    1,103
    Jan 4, 2017
    New York
    Are we talking super 10 transmission?
  4. tscottme
    tscottme Road Train Member
    Instead of throwing the gear lever to change gears & use air splitter to move between lo & hi-range you flip the splitter to move from even to odd gears. You only throw the stick on every other gear.
    Say you start in starting gear (1 or 2). Accelerate, at RPM where you would shift gears, flip splitter, lift off "gas" pedal, then mash on gas pedal. At RPM to shift gears, lift on gas, while in between gear position drop the splitter to low and put the stick in next slot. Accelerate, at RPM for shift, lift and flip the splitter.
    Until you are used to it don't skip any gears and plan on stopping at every traffic light. You use the splitter on every other gear shifting up & down, you throw the stick half as often as the 9/10 speed.
    Hype6477 and Bud A. Thank this.
  5. Sumtinlidat
    Sumtinlidat Light Load Member
    120
    261
    Dec 17, 2017
    Las Vegas Nevada
    10 wheeler with a strong arm?
    Watch how you take turns. Fully loaded it’ll be top heavy.
    Hype6477 Thanks this.
  6. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    This ought to help
    Hype6477 and tscottme Thank this.
  7. BKLusk64
    BKLusk64 Light Load Member
    106
    59
    Nov 17, 2012
    Drive it like the high side if a 13/18. Or if you ever drove a single axle with a two soeed rear.
  8. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    You can split each gear instead of having a range sector in the "middle". They are nice.
