Super 10 issues
Discussion in 'Ask An Owner Operator' started by JonasTtrucker, Feb 16, 2019.
  1. JonasTtrucker
    JonasTtrucker Light Load Member
    53
    Apr 26, 2018
    St. Louis, MO
    I have a super 10 transmission with an odd, annoying problem. When going into 9th gear the speedometer drops to zero and it will not shift into 9th. If anyone has had a similar issue would sure like to hear.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I use to have a super 10.
    Get rid of it & get a 13 speed.
    BUMBACLADWAR Thanks this.
  4. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Sounds like maybe 9th may be wiped.The higher gears are usually the first to go. Pull the plug and see if there's any large pieces of metal on it, If there is, take Bakermans suggestion. Make sure you plug the hole, so all the oil doesn't run out, I usually use my middle finger.
  5. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Hate those "Super 10's...It was a Drill in Trucking School..an Old Man Yelling at Ya.."Pull The Splitter".
  6. fss99701
    fss99701 Medium Load Member
    327
    663
    Feb 14, 2019
    none of your business
    if you end up replacing the transmission the Best transmission ever built is a 18-speed you can shift it just like a 9-speed or you can split any one of the gears very handy for climbing hills that's pretty much all we run in Alaska and northern Canada.
    Second choice would be a 13 speed.
  7. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Is it a Super 10 "Top 2" by any chance? The Top 2 has the option of shifting between 9th and 10th automatically. Its a setting in the ECM. If its consistently losing speedo and not able to make the shift to 9th, try skipping like you're going straight to 10th. (wind 8th up high and allow a deep rpm drop on the shift)
    The speedo problem is puzzling. Possibly someone routed the speed sensor cable in the area of the shifter. It could cause problems and in a Top 2 possibly make the ECM flake out on the auto shift putting the trans in 10th when selecting that position.
    Finally. don't listen to these "replace with" guys. What they mean is "I don't like something so its useless and I have no problem spending your money." Super 10 is a great trans as 10speeds go. When you get the hang of using one its a dream. 13's and 18's are great but are a "nice to have" for 99% of trucking.
    Tombstone69 Thanks this.
