super 10 vs. straight 10
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dalejr8fan, Mar 22, 2007.
  1. dalejr8fan
    dalejr8fan Light Load Member
    95
    Mar 13, 2007
    zephyrhills fl
    hey guys
    what is the difference between a super 10 transmission and a straight 10. which of these is harder to shift. thanks for and responses.
  3. pjw044
    pjw044 Heavy Load Member
    Super 10 is harder to shift at first, but gets easier as you go.
    S-10 has a lever on shifter handle like a 13 speed.
    Do a search on the Eaton Trans web site and it will talk all about it.
  4. dalejr8fan
    95
    Mar 13, 2007
    zephyrhills fl
    thanks pjw. trying to get info on this. the company im going with has automatics and super 10s. i dont want an automatic so it looks like im going to be in a super 10.
  5. Young-Gun-101
    Young-Gun-101 Light Load Member
    102
    10
    Feb 18, 2007
    Iowa
    ill try to explain somebody else may be able to better but, straight ten has a high/low splitter in the front of the shifter with 5 gears on the low side and 5 gears on the high side.
    now the super 10 is a little harder to explain so bare with me a super 10 has the spiltter for the gears on the left side of the shifter instead of on the front. and you go through two gears before shifting to the next hole.
    In my opinion I like the super 10 better, but the straight ten is easyier and less expensive which is why bigger fleet companys use straight tens and nicer to learn on . If you have any questions ill try to explain better.
    Thanks Mike:biggrin_25519:
  6. Sentinel
    Sentinel Bobtail Member
    40
    9
    Dec 18, 2006
    The Blacklands Of Texas
    Hi All,
    There is a video on the Eaton site you can download that shows the shifting of the Super 10. Here is a link to the Super 10 info and video:
    http://www.roadranger.com/Roadranger/SearchResults/index.htm?ssUserText=super+10
    Never drove one so would take a little getting used to but looks like it would be a good deal. It is almost like having half an auto as half the shifting is done for you at the flip of a switch and release/press of the accelerator.
  7. DeepC
    DeepC Bobtail Member
    22
    Largo, Fl
    I like the straight better. Every once in a while if I forget what gear I'm in (especially in traffic) with the straight ten I can just grab the shift handle and feel what position it's in. With the super you can be in one of two gears--takes a little thought to figure out what gear you're in. When I'm in places like Atlanta--rush-hour I don't have time to think--just re-act!
  8. rangerman1
    rangerman1 Light Load Member
    80
    6
    Mar 27, 2007
    Cheney, Wa
    Just curious what company? Admittedly ya get razzed for it, but the autoshift has me intrigued. Don't wanna be tied down to quitting if I don't like em, so a co' with both...... Super 10's are tricky at first, but NICE when you get used to them. Basically, you have a pre-select lever like regular, but the gears are 1st/2nd in the normal 1st gear position. What'd be 2nd in a regular trans, is 3rd 4th. same pattern all up through 10th. When you shift up, you just hit the clutch, pull it out and put it back in. (crap, does that sound dirty?) :-D
  9. biggen6776
    biggen6776 Bobtail Member
    34
    Mar 26, 2007
    super 10 is easier do to less shifter move movement.
  10. uncle bill
    uncle bill Bobtail Member
    40
    May 1, 2007
    The super 10 is super easy, which is why so many companys buy them. Drivers like'em!
  11. chargingbear
    chargingbear Light Load Member
    65
    May 11, 2008
    murray , utah
    i got hired back to my old company after quitting they said sorry your going in the older long nose with the super ten transmissions, i told them thank you i like them older trucks much more power and less clutching with the super ten in traffic. i drove one in school and i liked it in downtown traffic
